August 29, 2026, 04:56:02 pm
Hoffman Amps Forum image Author Topic: #22awg solid  (Read 7491 times)
Offline etneccas
#22awg solid
« on: May 29, 2020, 03:55:23 pm »
Can #22awg solid Wire be used for the heaters on a deluxe reverb build?
Offline vampwizzard
    • Walbertedwards.com
Re: #22awg solid
« Reply #1 on: May 29, 2020, 04:45:31 pm »
pretty good discussion here: https://el34world.com/Forum/index.php?topic=18618.0
Offline labb
Re: #22awg solid
« Reply #2 on: May 29, 2020, 05:36:18 pm »
most charts I see rate 22 gage wire for in chassis wiring at 6.3 amps. Some at 7 amps.
Offline etneccas
Re: #22awg solid
« Reply #3 on: May 29, 2020, 06:29:34 pm »
How many amps are on the heater wires of a deluxe reverb AB763?
The insulation on the wire I have is rated for 600volts
Re: #22awg solid
« Reply #4 on: May 29, 2020, 06:40:20 pm »
Go here and look up each tube. It'll take you the same amount of time to add it all up as anyone else.
     http://tdsl.duncanamps.com/tubesearch.php
Offline etneccas
Re: #22awg solid
« Reply #5 on: May 29, 2020, 07:29:19 pm »
 Thanks Sluckey but,Oh boy a little confusing what some of symbols mean on the charts....300ma?....4-12ax7’s and 2-12at7’s and 2-6V6’s
Under 3amps correct?
22awg rating for 7amps
Less than 50% of the rating........
Nothing to worry about?
Re: #22awg solid
« Reply #6 on: May 29, 2020, 07:42:43 pm »
I get 2.7A. I'd say you're good.
That's a good website link. I have it on my bookmarks bar for easy access. Maybe you'll want to save the link too. Comes in handy for amp builders. The more you look at tube data the more sense it will make. Don't worry about learning all at once. Take your time.
Re: #22awg solid
« Reply #7 on: May 30, 2020, 09:16:17 am »
FWIW, i'll use 20AWG for the power tube string IF there are 4 power tubes. i use 18AWG for 6 or more power tubes (depending on type), and for the string of preamp tubes i'll switch to 22AWG if there are less than 6-7 typical 300mA 6V preamp tubes. for 2 power tubes and up to 8-10 typical preamp tubes, 22AWG works fine.
use PTFE insulated wire. it is a far superior insulation to cloth/PVC or PVC. i have no idea why anyone uses cloth/PVC wire - IMO it's garbage.
ampacity ratings for chassis wiring are fairly conservative, even more so if putting wire inside of any kind of pipe.
