August 29, 2026, 04:55:27 pm
Hoffman Amps Forum image Author Topic: Assessing gain on 5879 morph control?  (Read 3929 times)
Offline luthierwnc
  • Should I mod this one or make another?
« on: June 03, 2020, 07:18:47 pm »
Hi All,  I'm going to try an idea I've had on the back burner for far too long.  It is just a 5F6a Bassman with the Morph control from Merlin Blencowe that Tubeswell and Tubenit did such great work on a few years back.  I'm borrowing Tubeswell's diagram in my attachments.
I'm curious about the gain levels as we would compare them to a dual triode-preamp tube across the sweep of the 1ma Morph pot.  From what I can tell of the datasheet on the 5879, in triode mode it has an amplification factor of 21 -- the same as a 12AU7.  In pentode mode, my sheet doesn't have an amplification factor and I can't tell from the charts how I would compare the two.
This is not keeping me up at night but I am curious -- and it would help in designing the faceplate -- perhaps using U, Y, T, X and ! instead of numbers.
Thanks for any help, Skip
Re: Assessing gain on 5879 morph control?
« Reply #1 on: June 03, 2020, 08:22:34 pm »
Its about  100 for that circuit IIRC
Offline luthierwnc
« Reply #2 on: June 03, 2020, 09:08:10 pm »
Thanks!  I've built them with the EF86 too -- probably a bit more, I'm guessing.  Hope your projects are going well.  sh
