September 14, 2026, 10:22:05 pm
Hoffman Amps Forum image Author Topic: Belden RG174 vs 9396 microphone cable  (Read 4071 times)
Offline Madkrafter
« on: June 03, 2020, 11:47:51 pm »
On my AB763 Blackface DR build, I am using shielded cable for the four tone circuit runs: inputs > V1, V2 pin 2 and Vol > V1, V2 pin 7. I have some Belden 9396 microphone wire from StewMac for some electric guitars that I made years ago. Does anyone know how this compares to RG174? There are differences in impedance and other electrical characteristics I admit I don’t quite grasp. Should I swap out my 9396 for RG 174?
Re: Belden RG174 vs 9396 microphone cable
« Reply #1 on: June 04, 2020, 12:59:20 am »
The ONLY electrical spec that ever matters in small audio is pFd/foot. And this rarely matters because nearly all coax is about 30pFd/ft.
BUT that 9396 is more than twice "normal". You don't want a run of even half normal length. For 6-inch runs it may not matter, unless you are obsessing for ultra-highs. It would be a poor choice for a 30-foot guitar cable for bright lead-riffs.
Are you having a problem or just in a reading-mood?
Offline Madkrafter
« Reply #2 on: June 04, 2020, 01:14:21 am »
Thanks PRR. I am not having a problem... yet. I am waiting on 6 resistors that were missing from my build kit. They should be here Friday from Antique Electronics. I have two of the four runs soldered. The other two need the missing resistors for the input jacks. I just placed another order tonight  :dontknow: for more resistors and a SPDT 3-position switch for RobRob's 3-Way NFB Switch mod. I also put some RG174 on my order. Sounds like it might be worth my time to switch it out since it's just a couple quick re-solder joints.
Offline Latole
« Reply #3 on: June 04, 2020, 03:30:22 am »
Sansteeth forum member find what it look a good shielded cable ;
https://el34world.com/Forum/index.php?topic=26059.0
Offline Tone Junkie
« Reply #4 on: June 04, 2020, 09:09:46 pm »
I just want to say . if you need parts quick Doug has the best and fastest service . Usually I have my order within 2 days and I live on the west coast. I guess a ( Thank You Doug) is in order.Thanks Bill
