September 14, 2026, 11:16:34 pm
Hoffman Amps Forum image Author Topic: Using Halo light switch as Power and standby switches  (Read 4697 times)
Offline Captain chunkulus
« on: June 09, 2020, 02:55:49 pm »
The switches are 250v@5amps.
If it were wired for 1:20 instead would it increase the switches amps to 10amps? Lastly, will these you can work for a tube amp build? Thanks in advance for any comments or directions.
Re: Using Halo light switch as Power and standby switches
« Reply #1 on: June 09, 2020, 03:05:23 pm »
probably, keeping the 5A rating, might be hard finding 12vdc for the LED
I would not try at 120V 10A unless you're ready for smoke and you have a boatload and they were free  :icon_biggrin:
« Reply #2 on: June 09, 2020, 03:09:18 pm »
Thanks shooter, that's what I needed to know. Do any of you guys have a solution for a low Pro profile push button switch with Incorporated ?
« Reply #3 on: June 09, 2020, 03:20:07 pm »
How about this?
« Reply #4 on: June 09, 2020, 04:00:06 pm »
this is my "go to" lighted switch
multiple colors, I just like blue  :laugh:
https://www.parts-express.com/parts-express-spst-large-rocker-switch-w-blue-illumination-125vac--060-704
your 2nd one didn't say anything about the "light" part, assuming it's powered from the mains, should work
