September 17, 2026, 12:52:51 am
Hoffman Amps Forum image Author Topic: Yet another AC15...  (Read 6883 times)
Offline archaos
Yet another AC15...
« on: June 17, 2020, 03:13:28 pm »
...Top Boost this time
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
Offline archaos
Re: Yet another AC15...
« Reply #1 on: June 17, 2020, 03:19:32 pm »
Hammond irons
PT : 290PX
OT : 1750T
Choke : 193C
« Last Edit: June 17, 2020, 03:49:20 pm by archaos »
Mehr Licht !
Offline archaos
« Reply #2 on: June 17, 2020, 03:48:33 pm »
Preamp : 12AX7 x 3
Power amp : EL84 x 2
Rectifier : 5Y3
The first tube preamp has its triodes connected in parallel (110k on the anodes ; 25µF/1k5 on the cathodes), as well as 2 x 68k in parallel on the grids.
The second tube preamp is wired exactly as was the original AC30 TB cathode follower.
The PI tube is wired as well as was the original AC30 TB as a LTP with .15µF coupling caps.
125µF/100R on the EL84 cathodes giving about 12.5W (plate-to-cathode voltage = 281.22 ; voltage across cathode resistor = 8.78).
No hum, no parasitic noise or something else, just bliss.  :icon_biggrin:
« Last Edit: June 17, 2020, 04:08:53 pm by archaos »
Mehr Licht !
Offline MORE_Guitar_Solos
  • Tubezzzzzzzzzzzz!
    • Xerobot on IG
« Reply #3 on: June 20, 2020, 07:10:13 pm »
Looks tight! Thanks for sharing.
What kind of speaker are you running?
Offline archaos
« Reply #4 on: June 21, 2020, 04:25:41 am »
Thanks ! It's a pair of blue Celestions from the early 90's having some mileage.
Mehr Licht !
  • Tubezzzzzzzzzzzz!
    • Xerobot on IG
« Reply #5 on: June 21, 2020, 07:21:01 am »
Did you build the cab too?
This is an incredibly sano build, very impressive.
Offline archaos
« Reply #6 on: June 21, 2020, 08:49:43 am »
No I didn't. It's an original AC30 TBX combo cabinet converted in a spkr cab. My AC15 will be housed in a head cabinet which is far easier to carry.
Mehr Licht !
Offline Bwmitc9285
« Reply #7 on: June 26, 2020, 01:22:07 pm »
Looks great! Did you make the faceplate yourself?
Offline archaos
« Reply #8 on: June 26, 2020, 03:01:18 pm »
Thanks ! No I didn't make it myself, I've just designed it with Inkscape then sent it to a custom shop to be laser engraved.
Mehr Licht !
Offline acheld
« Reply #9 on: June 28, 2020, 09:52:52 pm »
Aha, another fan of RG316!
What pots are those?
Offline archaos
« Reply #10 on: June 29, 2020, 01:36:29 am »
Yes, I am !  :icon_biggrin:
Those are Bourns PDA241.
Mehr Licht !
