September 08, 2026, 11:24:02 am
Hoffman Amps Forum image Author Topic: Old Silvertone ; broken pickgard repair, more pictures  (Read 8818 times)
Offline Latole
« on: June 24, 2020, 07:41:11 am »
I use a Fender Stratocaster tremolo spring back plate to make a piece to fit where the pickguard is broken.
Output jack was missing
Before :
DSC08024
After :
DSC08057
'60 Simpson Sears catalog ad :
DSC08034
« Last Edit: June 25, 2020, 04:01:42 am by Latole »
Offline Latole
Re: Old Silvertone ; broken pickgard repair
« Reply #1 on: June 25, 2020, 04:01:02 am »
More picture
Before :
DSC08032
After ;
DSC08050
Offline Latole
Re: Old Silvertone ; broken pickgard repair, more pictures
« Reply #2 on: June 30, 2020, 03:56:49 am »
All pots shaft are split shaft with knob with a set srew; all original.
Set screw pot are for solid shaft. On a split shaft, knob with a set screw could break the shaft
I make a solid shaft with hard plastic piece
DSC08078
Offline Latole
« Reply #3 on: June 30, 2020, 04:02:17 am »
All tuning machines do not work properly. They are all dry from grease.
I spray white lithium grease. Now tuning machines work properly.
They have access hole for grease we can't see on the picture.
DSC08076
Offline Latole
« Reply #4 on: June 30, 2020, 04:08:21 am »
Vibrato tailpiece position look bad, spring is too soft making a wrong angle.
There is no vibrato arm.
I make a blocking tremolo with a piece of 1/4 " plumbing copper pipe.
Now tailpiece look better.
Before ;
DSC08066
After ;
DSC08071 copie  Flickr
« Reply #5 on: June 30, 2020, 04:30:43 am »
You have done a great job on the restoration!    :thumbsup:
Offline Latole
« Reply #6 on: June 30, 2020, 04:57:46 am »
Thank youTubenit, your comment is very appreciated because I know that you have managed a good job in amps and guitars
« Reply #7 on: June 30, 2020, 09:05:52 am »
 :thumbsup:
« Reply #8 on: June 30, 2020, 10:29:18 am »
Nice!
when you get bored with the guitar there are a couple build threads for Silvertone amps to compliment your guitar  :icon_biggrin:
Offline Latole
« Reply #9 on: June 30, 2020, 10:46:26 am »
Nice!
Thank you, I know Silvertone make few good amps.
It is a customer guitar, not mine.
I do some work on guitars these days, because I'm bore to work on amp :laugh:
