September 17, 2026, 02:09:48 am
Hoffman Amps Forum image Author Topic: Looking for Blue Jewel, or Blue Power ON Light  (Read 8468 times)
Offline dinkyguitar
« on: June 25, 2020, 05:01:53 pm »
Hi All,
Not sure if this belongs here, but I have a blue jewel, but when the amp is powered on, it shines white.
Anyone have this issue?
I was trying to see if i could get a blue light bulb to make it blue, but haven't found one yet.
I'm using these.
https://www.mojotone.com/amp-parts/PilotLights_1/1-2-Lens-Assembly-Blue-Jewel
After looking at this picture...is it supposed to turn white when it's powered on?
dinky
Re: Looking for Blue Jewel, or Blue Power ON Light
« Reply #1 on: June 25, 2020, 05:23:01 pm »
go to the hobby store, pick up a small glass of blue paint for models.  enamel, not sure urethane will like the heat  :icon_biggrin:
« Reply #2 on: June 25, 2020, 05:31:54 pm »
Buy one from Hoffman.
« Reply #3 on: June 25, 2020, 05:50:36 pm »
Normal incandescent lamps make very little blue. Mostly red. Even with a blue filter they look white.
Convert to blue LED. It can be fed 6.3VAC through a 330 Ohm series resistor, but will flicker if you move your head fast. Two blue LEDs anti-parallel on one 330r will flicker less, and less reverse-stress on the LED. There are cleverer plans but it's only a pilot light.
Offline Latole
« Reply #5 on: June 26, 2020, 02:59:41 am »
Hi All,
I'm using these.
dinky
On the link one picture show you it come white when power ON
Offline dinkyguitar
« Reply #6 on: June 26, 2020, 06:57:24 am »
https://www.ebay.com/c/1031492460?iid=252495546075
Have you tried these?
@Latole
I did see that pic you are referring to....which is why I'm curious if it's supposed to be like that....
But if you're getting a colored jewel, wouldn't you want it to stay that color when powered on?
Offline Latole
« Reply #7 on: June 26, 2020, 08:18:29 am »
Not realy, IMO color of jewel is not dark enough to stay blue
« Reply #8 on: June 26, 2020, 12:08:01 pm »
Id say Pete's idea of a blue LED inside a blue jewel is worth a try.
Offline Latole
« Reply #9 on: June 26, 2020, 02:48:31 pm »
You are right.
We don't know how many Lumens this LED. With this led, amp pilot light may not be very bright in daylight
« Last Edit: June 26, 2020, 03:11:09 pm by Latole »
« Reply #10 on: June 26, 2020, 02:53:48 pm »
Offline Latole
« Reply #12 on: June 26, 2020, 04:19:59 pm »
yes. they work fine. i used the dialight brand in red, they were more expensive and now not readily available. LED lamps do last longer than an incandescent lamp.
the seller i linked to is reputable - i have purchased from them in the past.
Offline dinkyguitar
« Reply #13 on: June 27, 2020, 09:38:47 pm »
Thanks everyone.....
I like the idea of the LED as well as the colored blue....might try both.
dinky
Offline acheld
« Reply #14 on: June 28, 2020, 09:46:38 pm »
The LEDs work great.  I've used them exclusively now for the past few years in various forms.
Achieving a rich blue color, however, is not so easy.   I have used Hoffman's blue jewel with several different blue LEDs, and they work fine as pilot lights, just not a rich blue.
Using a hard wired LED is simple -- you just have to put a current/voltage limiting resistor in series.  This should be in the range of 180-200k @ 20mA, ie a 1/4 watt resistor is fine.   You can buy these pre-made on eBay (like everything else, it seems) very inexpensively.
If you have a Fender lamp socket installed, there are pre-made LEDs (with the voltage limiter inside) that fit the sockets.  There are several vendors that are selling these -- frankly they are so cheap that you can't go wrong.  I've had vendors ship from China, Hong Kong and the US.   US shipping is the fastest, but they all work.
« Reply #15 on: June 29, 2020, 12:20:07 am »
Not "k". Just little Ohms.
Offline Latole
« Reply #16 on: June 29, 2020, 07:46:05 am »
Original # 47, 6.3 volts incandescent bulb are cheap. I'll buy blue paint in hobby shop ( very very small can ) tp pint the bulb.
Or blue colored cover for your bulb ;
Cover:
https://www.bulbtown.com/Blue_Colored_Bulb_Cover_For_T3_1_4_Bulbs_p/39-12-5a.htm
Bulb
https://www.bulbtown.com/47_Miniature_Bulb_Ba9S_Base_p/b47.htm
« Last Edit: June 29, 2020, 08:16:37 am by Latole »
