September 16, 2026, 10:22:52 pm
Hoffman Amps Forum image Author Topic: 100W Quad EL34 Scratch Build Project  (Read 6154 times)
Offline wiperandtrue
« on: June 26, 2020, 02:57:31 pm »
Having, as most of us, found myself with a lot of free time on my hands, it seemed a perfect opportunity to finish a project that I started about three years ago.
General advice for building a valve amplifier is to start small, ideally using a ‘make-your-own’ kit. I have not done that. Not even close. I’m kicking off my sojourn into homebrew audio electronics with a 100W bass amp using Partridge transformers salvaged from a Carlsbro TC100, with a circuit and chassis of my own design. This is my second attempt at this undertaking. The first edition has sat untouched on my desk for the past year serving as a fluctuating source of agitation that would peak when upon watching my ex-girlfriend’s eyebrows reach escape velocity when I told people that I was working on it. Yes I’m fucking building it Jenny.
Here's the design:
Everything before the phase inverter is likely to change as I build and test, so pay it little mind. This post will mainly be my reasoning for the power amp and power supply. It's a bit of a wall but I find it useful to write out my thought process. I've mainly followed Merlin's methodology for designing a PP amp. I welcome you to point out any daft mistakes. I'm a first-time builder diving into a project way beyond my ability level. It's an inevitability. I have already highlighted three queries that I would greatly appreciate assuaging.
I have actually started buidling the amplifier; it's just taken me this long to get around to writing up this post though I'm not too far along to not be able to adjust the design so again, I ask for your honest critique.
Naturally I don't have any information on the transformers. But I do have a variac and a multimeter... The average voltage ratio was 17.6, the square of which, 311.2, is the impedance ratio. Given that these measurements were taken from the 16 Ohm output tap that gives us a primary AC impedance of 311.2 * 16 = 4980R which we can safely round up to 5k.
My mains voltage today was a toasty 236.5 Vrms, which presented on the secondary of the power transformer as 357.2 Vrms. Once converted to DC by four UF5408 we should have a HT voltage of 357.2 * 1.414 - (2*1.7) = 501.8 V however the measured voltage is actually 494 V. Any ideas? The amp that the transformer comes from has a HT of 470 V so the measured value is closer but still much higher. Is this because I've taken the measurement with no load applied? When taking the measurements only the bridge rectifier and reservoir capacitor were hooked up. For the time being I'm going to assume a HT voltage of 480V as it's a happy medium between the HT used in the amp that the PT was pulled from and the measured voltage.
The impedance 'seen' by the tubes in each class of operation is therefore:
Class A = 480 V / 2500 R = 0.192 A
Class B = 480 V / 1250 R = 0.384 A
I spent far longer than I care admit wondering why drawing load lines using these values put the operation well outside of the EL34s maximum thermal dissipation until remembering each side of the power amp has two EL34s in parallel. They each supply half of the current!
The maximum thermal dissipation at the HT is 25 W / 480 A = 52 mA. I'm aiming for an initial biasing point of 75% of this which is approximately 40 mA. This necessitates a bias voltage of 20V. Which brings me to question two - the schematic for the TC100 shows a bias voltage of -37! which seems way too low. Am I misreading the schematic? Could I take from this that my measurement of the OT impedance is incorrect?
The current flowing in the screen-grid dropper resistor will be the grid current of the four EL34s plus the preamp valves. The datasheet suggests a 20:3 anode to screen current ratio, so = 40 ma * (20 / 3) = 6 mA screen current per EL34. The preamp valve complement is an ECC832, ECC83, and ECC81 with respective typical current draws of 20 mA, 2.4mA, and 11.7 mA. The total current through the screen-dropper is therefore (6 * 4) + 20 + 2.4 + 11.7 = 58.1 mA. This is a fair whack of current so I've chosen a small dropper value of 100R to limit the voltage drop to 58.1 mA * 100R = 5.81V.
The screen stopper resistors are 1k so they will also drop 1k * 6 mA = 6 V. The final screen voltage will therefore be 480 - 5.81 - 6 = 468.2 V, a good 18 volts above the EL34 maximum screen voltage of 450V. Is my HT too high? Do I need to increase the size of the dropper resistor to drop more voltage? Or can I leave it at this value expecting the voltage to sag when under load?
That is it for today. Tomorrow I'll start posting build progress pictures. I'll be including any mistakes and how I managed (or failed) to rectify them for both educational and entertainment purposes.
Re: 100W Quad EL34 Scratch Build Project
« Reply #1 on: June 26, 2020, 03:36:15 pm »
Welcome.
> 501.8 V ......is actually 494 V
That's not even 2%. Is your meter good to 2%, from one range to another?
Plan to have four 1 Ohm resistors so if a tube quits you don't over-bias its mate to get the right reading.
« Reply #2 on: June 27, 2020, 09:16:49 am »
the LTPI as designed with the 68K tail R may disappoint. that stated, also based on the assumption LTPI is a 12AX7. as designed, it would be better suited to drive a quad of EL84s.
