September 17, 2026, 10:33:15 am
Hoffman Amps Forum image Author Topic: Low volume, heavily distorted output  (Read 6045 times)
Offline AHeck
« on: June 30, 2020, 11:33:06 pm »
I just fired up a 5E3 build and the output is just wrong. It’s making guitar noises, just heavily distorted and with hardly any volume.  My voltages are good, I’ve tried three complete tube changes, checked resistance from tip to sleeve in all input jacks, tried two different guitars, and cables, also I reversed the output jack polarity.  One thing that I checked that seems suspicious is without the power tubes, the output leads show about 6M continuity with the plate pins and output transformer center tap.  I would think that should be an open lead.  Is that worth digging into?  Thanks for any help .
Offline Latole
Re: Low volume, heavily distorted output
« Reply #1 on: July 01, 2020, 03:08:04 am »
 " the output leads show about 6M continuity with the plate pins and output transformer center tap. "
-AHeck
Issue is there. Power transformer primary look bad....If you use the right wire   :laugh:
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #2 on: July 01, 2020, 11:24:03 am »
It sounds like you are measuring the resistance across your first filter cap.
An actual 5E3 has two speaker jacks.  One is a shorting jack and the other open.  If you plug into the open jack, you just might get the symptoms you describe.
Offline 2deaf
« Reply #3 on: July 01, 2020, 11:32:06 am »
There's this guy on the Marshall Forum called South Park.
