September 08, 2026, 07:12:32 pm
Hoffman Amps Forum image Author Topic: tools for making your own boxes  (Read 11348 times)
Offline PRNDL
  • Tube or not Tube, that is the question
« on: January 22, 2008, 11:08:00 am »
Does anyone make their own boxes?
I'm wondering what tools would be appropriate for a hobby shop.
Sure, it would be cool to get a combo shear/brake for $400 + $200 shipping, but can this be done with inexpensive tools?
Check out my new tweed Retro 6V6 combo
http://www.naturdoctor.com/Chapters/Amps/RetroV.html
Paper-in-oil caps are cool!
Offline sawdust
  • tube amps are cool
Re: tools for making your own boxes
« Reply #1 on: January 22, 2008, 06:44:23 pm »
Harbor Freight has some bending/brakes for less than $50. Some may have had a sheer too, I'm not sure. I went by there the other day and almost bought one for $27, seemed ok for $27. The more you spend the bigger the unit.
Dave
Dave in Dacula
Offline texasrockguy
« Reply #2 on: January 24, 2008, 06:04:34 pm »
i bought one of the 27 buck harbor freight brakes and it does not do a good job on .080 aluminum. i am saving my pennies for a bigger brake to make chassis with. i have used rivets in the past to make simple chassis with a little creative thinking and it works well enough.
heres one i made from old aluminum shelves.
http://i137.photobucket.com/albums/q234/texasrockguy/graham806012.jpg
http://i137.photobucket.com/albums/q234/texasrockguy/graham806013.jpg
http://i137.photobucket.com/albums/q234/texasrockguy/graham806014.jpg
http://i137.photobucket.com/albums/q234/texasrockguy/graham806015.jpg
takes a little doin but it does work.
Offline billcreller
  • 1934
« Reply #3 on: April 05, 2008, 02:45:47 am »
I realize this thread is old, but bending chassis with a straight brake (cornice brake) is limited.  I have one, but bending the ends in isn't possible, so I make them separate and rivet them in, or TIG weld them in.
  A box brake is ideal. A box brake has removable sections of various widths.   A friend has one that I use sometimes , if I feel like driving over there to use it.
Offline loogie
« Reply #4 on: April 05, 2008, 07:32:47 am »
I have a $50 brake and I've cut fingers out of wood.  It works well for thin alumium.  I haven't tried it on anything about .050.  My brake is basically a hinged hunk of iron with another hunk you clamp on top to fold around.  I was thinking of having this top piece cut into smaller pieces so I could have real fingers.
I've also found that the aluminum solder sticks you can buy at big box hardware stores or from the internet works real well with a Mapp gas torch.
I make amps for friends so I don't know if the chassis could handle the rigors of heavy road duty, but I think if properly constructed the folding, soldering approach would work.
