September 17, 2026, 07:06:59 pm
Hoffman Amps Forum image Author Topic: Speed Twin Bias Setting  (Read 4341 times)
Offline dpm309
    • Matthews Amps
« on: July 03, 2020, 04:37:30 pm »
What would be a target bias setting for a 100 Watt TE Speed Twin using KT77s. Swapping out the original 18 YO EL34s. The bias probe and adjustment pot are easily accessible from the rear.
Re: Speed Twin Bias Setting
« Reply #1 on: July 03, 2020, 05:32:39 pm »
You need to consider plate voltage to determine proper mA
Offline dpm309
    • Matthews Amps
« Reply #2 on: July 03, 2020, 05:44:05 pm »
Plate voltage is about 425VDC. I reinstalled the Weber bias Calculator (hard drive crashed and lost all of my bookmarks) and according to it, I should be looking at 35mA. I read that you can bias the KT77s a little hotter, so I might go for closer to 40mA. Sorry, should have checked the bias calculator first.
« Reply #3 on: July 03, 2020, 05:51:37 pm »
That sounds good. No need to be sorry. Its just you cant tell one without the other.
Offline dpm309
    • Matthews Amps
« Reply #4 on: July 03, 2020, 06:21:24 pm »
