September 18, 2026, 08:23:21 am
Hoffman Amps Forum image Author Topic: Four Prong Pot Question  (Read 5080 times)
Offline dbell7
« on: July 15, 2020, 11:24:40 am »
Hi, I recently bought a used Fender Sidekick 65 Bass that was made in japan, and the four-prong master pot is broken. I came across Hoffman's 350KA pot with tap point, and was wondering if this would be a good replacement to the A10K knob that was there before, since they both have four prongs.
Re: Four Prong Pot Question
« Reply #1 on: July 15, 2020, 11:50:04 am »
You need to give the guys more info
Post a schematic link so they can see what your map has
Offline dbell7
« Reply #2 on: July 15, 2020, 12:00:54 pm »
That's just the thing, I can't find any information on the amp anywhere.
« Reply #3 on: July 15, 2020, 12:46:01 pm »
trace the 4 wires, make a sketch and post
10k is typically NOT a good swap for 350K even if they are both 4 legged
« Reply #4 on: July 15, 2020, 01:04:08 pm »
Short answer... NO.
Here's the schematic. You can use a 10K-A without the tap.
Offline Latole
« Reply #5 on: July 15, 2020, 01:32:50 pm »
Some Fender 10 K here, not with 4 lugs.
Could be useful if you want to use same knob?
https://darrenriley.com/product-category/fender-amp-parts/potentiometers/
Few more informations on Sidekick amps:
https://www.schematichell.com/fender/Fender_Sidekick-15-25R-35R-65R_sch.pdf
« Last Edit: July 15, 2020, 01:36:12 pm by Latole »
Offline dbell7
« Reply #6 on: July 15, 2020, 04:08:06 pm »
Do you suggest I forget about the four prongs, and just stick with a three prong as long as it matches the numbers?
« Reply #7 on: July 15, 2020, 04:14:44 pm »
