September 19, 2026, 11:10:13 pm
Hoffman Amps Forum image Author Topic: Isolate terminal ground lugs from chassis?  (Read 5213 times)
Offline jonathan_kea
« on: July 18, 2020, 09:31:52 am »
Now that I’ve got it working, I want to make some changes to the layout on my 5C1 build.
I’m working with a six lug terminal strip in the power supply and want to bring the 6v6 cathode resistor over so it can share a common ground with the filter caps.
The only problem is that I am out of lugs. Is there a proven way to lift the two outer ground lug connections off the chassis so they can accept positive voltage? I’m thinking about using nylon washers - has anyone attempted this before?
Offline Latole
Re: Isolate terminal ground lugs from chassis?
« Reply #1 on: July 18, 2020, 09:58:04 am »
I don't know what you mean "....using nylon washer."
Post picture of your wiring.
I use that kind of terminal strips: Vintage parts.
https://www.tubesandmore.com/products/terminal-strip-5-lug-1st-lug-common-horizontal-package-5
« Last Edit: July 18, 2020, 10:00:29 am by Latole »
Offline vampwizzard
    • Walbertedwards.com
« Reply #2 on: July 18, 2020, 10:00:26 am »
You'd have to isolate the terminal thats hitting ground as well as isolate the fastener from terminal.. i.e. youll need to use a nylon screw. Id look for other options.
« Reply #3 on: July 18, 2020, 10:01:26 am »
grab nylon screws and nuts while you're at it, otherwise you just make it taller  :icon_biggrin:
« Reply #4 on: July 18, 2020, 10:15:22 am »
Excellent point on the screw and washer! I would have use a metal screw and nut, totally defeating the purpose and probably catching my house on fire.
Latole - Will check into those horizontal terminal strips too. Might be a better fit. Thanks all!
« Reply #5 on: July 18, 2020, 11:12:45 am »
Bad idea. Don't do it.
« Reply #6 on: July 18, 2020, 12:36:29 pm »
Agreed. Going to use an extra strip.
