September 15, 2026, 10:14:18 pm
Hoffman Amps Forum image Author Topic: AB763 w/bias shifting tremolo  (Read 9257 times)
Offline aabbs20
« on: July 21, 2020, 11:53:41 am »
Hey all,
I'm planning a single channel Deluxe Reverb AB763 type amp and I'd like it to have bias-shifting trem instead of optocoupler. I'm planning on using the 5G9 type since I'll have two triodes and it's my favorite trem. Has anyone done this? Is there anything I should be aware of while I'm drawing the layout/schematic?
« Last Edit: July 21, 2020, 02:13:51 pm by aabbs20 »
Offline vampwizzard
    • Walbertedwards.com
Re: AB763 w/bias shifting tremolo
« Reply #1 on: July 21, 2020, 12:24:28 pm »
« Reply #2 on: July 21, 2020, 01:32:28 pm »
I'm planning a single channel Deluxe Reverb AB763 type amp and I'd like it to have bias-shifting trem instead of LFO.
All tremolo circuits use a LFO. Maybe you meant to say roach or Fender neon optocoupler?
Hoffman has exactly what you are looking for...
     https://el34world.com/Hoffman/files/Hoffman_AB763_1.pdf
Offline aabbs20
« Reply #3 on: July 21, 2020, 02:19:23 pm »
Yes...you're correct, I meant optocoupler.
That looks great, I'll order up the board.
Offline Joel
« Reply #4 on: July 21, 2020, 05:49:21 pm »
You won't be sorry.  It's a brilliant amp.  Paired up with a WGS ET65 or G12C... magic.
One day I'll have my workshop built and sorted and I'll have the outdoor garden projects finished for the wife, then I'll be able to look into installing Sluckey's Trem-O-Nator mod.
The mouth of a happy man is filled with beer  - Egyptian Proverb
Offline vampwizzard
« Reply #5 on: July 21, 2020, 06:08:22 pm »
ET65 is my current favorite speaker. LOVE them.
Offline aabbs20
« Reply #6 on: July 21, 2020, 11:37:13 pm »
I took a deeper look at the schematics tonight and it looks like there are a number of component differences between the 5G9 and Hoffman trem circuits. Are there advantages/disadvantages to either one? Is the Hoffman version preferable?
« Reply #7 on: July 22, 2020, 08:19:45 am »
Hoffman's tremolo circuit was taken from the 6G16 Vibroverb, not the 5G9.
Offline vampwizzard
« Reply #8 on: July 22, 2020, 09:57:39 pm »
two different beasts. The 5G9 is oscillating off straight B+ while the vibroverb is oscillating off the bias circuit. In an AB763 with a negative bias circuit,Doug's/Vibroverb would be my go-to.
« Reply #9 on: July 22, 2020, 11:09:24 pm »
> 6G16 Vibroverb, .... 5G9
Offline aabbs20
« Reply #10 on: July 23, 2020, 09:37:35 am »
Thanks guys, this is very helpful. It seems like 6G16 is the preferred method. Why though? More stability? Better sounding trem? It seems like it puts a higher voltage on the plates, could that be an issue?
Can you explain this in more detail? To me it looks like both are connected to the B+ supply and the bias circuit in a similar way.
Offline vampwizzard
« Reply #11 on: July 23, 2020, 12:06:52 pm »
Rob Robinette explains the difference between the 5E3 and Blackface deluxe a lot better than I could.. find "Differences Between the 1950's Tweed and 1960's Blackface" https://robrobinette.com/How_The_AB763_Deluxe_Reverb_Works.htm
To answer your questions: Yes more stable, yes better sounding trem when youre pushing the output of the PI and output sections, and the higher plate voltage is part of the recipe there. Theres a reason Fender went that direction.
« Reply #12 on: July 23, 2020, 12:32:31 pm »
They are. Both must have B+ to operate. Both modulate (vary) the fixed bias supply to create the effect.
Both circuits are almost identical, but with very slight differences, and some differences in component values. The 6G16 came along several years after the 5G9. Consider the vib circuit to be a slight upgrade. Study the pic that PRR posted to easily see the similarities and differences.
Offline aabbs20
« Reply #13 on: July 23, 2020, 03:29:12 pm »
Of the bias modulating trems the 5G9 is my favorite so far, so if the 6G16 is a slight upgrade that will be very exciting.
Thanks all, I'll report back on how the build goes.
Offline aabbs20
« Reply #14 on: August 04, 2020, 11:16:40 am »
The build is complete and sounding amazing. The 6G16 tremolo is to die for too.
I've got the 47k resistor to ground to compensate for the lack of optocoupler tremolo but it still has a little more gain that I'd like. Is there a preferred way to ditch some of that?
Thanks all.
« Reply #15 on: August 04, 2020, 01:24:59 pm »
I used a 100K master volume pot instead of the 47K. Let's me ditch as much as I want, or even boost the signal if desired.
Offline vampwizzard
« Reply #16 on: August 04, 2020, 09:30:56 pm »
Sluckey: that’s the one complaint I’ve had with my build.. it got incredibly loud very quickly. Felt it was a feature and not a bug. It’s the loudest 6v6 amp I’ve ever played
Offline Bieworm
  • I like it loud!
« Reply #17 on: August 17, 2020, 04:14:23 pm »
Changed the opto trem of my vibro King to bias vary. It's perfect now...no trouble at all. And that's a 60W 6L6 amp!!!
Offline MWaldorf
« Reply #18 on: August 17, 2020, 11:37:40 pm »
about 20 years ago, before I started futzing with amps myself, I had a tech install the 6G16 bias trem in my '67 Twin Reverb.  Not only is the tone great, but it doesn't reduce the average volume the way the shunt-to-ground optoresistor circuit does.
