September 16, 2026, 04:14:47 am
Hoffman Amps Forum image Author Topic: recognize this Supro?....no tremelo...no schematic info on web....?  (Read 5385 times)
Offline skallywampus
Looking for the reason no tremolo and a beginner at this and no schematic to help sets me back. Do any of you know of a similar schematic I may learn from?
thanks, Skallywampus
Re: recognize this Supro?....no tremelo...no schematic info on web....?
« Reply #1 on: August 02, 2020, 12:26:55 pm »
Here's Doug's schematic page, find something you like, maybe we can  help start the process
https://el34world.com/charts/TubeAmpSchematics.htm
« Reply #2 on: August 02, 2020, 12:47:58 pm »
Tell us what tubes are in it. Show us some pics of the chassis, inside guts and outside layout.
Your schematic is not complete and the input jacks are connected to ground.
« Reply #3 on: August 02, 2020, 01:17:21 pm »
thank you ..drawing the schematic as I go....(hurricane outside anyway...)  here are some more pics. There is an ID plate x79202....
Offline vampwizzard
    • Walbertedwards.com
« Reply #6 on: August 02, 2020, 02:57:20 pm »
The LFO seems taken from Supro 1690T. The fact the audio stage is triode or pentode is probably not very important.
Offline Latole
« Reply #7 on: August 02, 2020, 03:05:06 pm »
Often with tremolo issue and if tube is good; I replace all tremolo circuit capacitors.
It's aways work....and cost only few $
« Reply #8 on: August 02, 2020, 03:56:23 pm »
here's the tube layout...
Offline bmccowan
  • Better builder than player
« Reply #9 on: August 02, 2020, 05:16:27 pm »
That's a pretty rare amp. I think VampW has it right. English Electronics was one of the Chicago music stores that Valco labelled amps for. Folks, including me, have looked for that schematic before. So if you sketch out the schematic, and post pics of the guts, folks here can help you fix the tremolo, and many, me included will be happy to have the schematic.
Mac
John Prine
Offline ALBATROS1234
« Reply #10 on: August 03, 2020, 04:22:02 pm »
yea thats a bad ass valco wouldnt mind taking a peek at its underbelly. weird how its got the 5979 mini with metal octals. ive seen a few like that with the preamp connected with the umbilical cord to the power supply/power amp. i bet it has the sweet gritty 50s valco sound too.
Offline bmccowan
« Reply #11 on: August 03, 2020, 08:03:09 pm »
Yup on the 5879. I thought I'd be able to find a very similar earlier schematic with a 6SJ7 in that position, but I did not. I have three Valco basket cases awaiting rebuilds. Two have separate preamps with an umbilical cord, but they are clearly different circuits. Valcos are hard to work on, what with the crowded terminal strips, but they are a ton of fun and tone!
Mac
John Prine
« Reply #12 on: August 04, 2020, 01:58:08 pm »
This is what I have for the tremolo circuit so far....no oscillation.
so...
jumped 22K on off switch.....no change.
jumped 1.5K Cathode 5879 ..no change
raised 1.5K to 3.9K on 5879...lowered volume start tremolo..not sustain
raised 1.5K on 5879 to 1meg....lowered amp volume and tremolo started and does not sustain
Paralleled  47uf cap on 5879cathode...no change
just shotgunning I guess....
« Last Edit: August 04, 2020, 02:06:30 pm by skallywampus »
« Reply #13 on: August 04, 2020, 03:54:15 pm »
Still likely errors in today's plan (cleaned and attached).
The 0.5u cap in the LFO phase-shift seems unlikely; 0.05 or 0.02 more usual.
Offline vampwizzard
« Reply #14 on: August 04, 2020, 09:23:44 pm »
Pretty interested in getting a working schematic out of this. Keep it up!
Offline bmccowan
« Reply #15 on: August 05, 2020, 06:01:34 am »
One of the Gibson GA-40 Les Paul models used a 6SQ7 for the tremolo and a 5879. The portion of the circuit in the sketch look pretty darn similar. Joe Piazza drew a very clean schematic of that amp. Maybe it helps.
Mac
John Prine
