September 08, 2026, 05:46:05 pm
Hoffman Amps Forum image Author Topic: Hiwatt DR103 FX loop  (Read 24799 times)
Offline SoundCity85
« on: August 05, 2020, 02:44:52 am »
Hello,
I recently finished building a DR103 preamp into a Sound City 6x EL34 amplifier. It sounds huge, but there is still need for an FX loop. Especially for effects like reverb/echo/delay, it's the sound of the preamp that needs to run through the FX instead of the signal of the guitar. I attached the schematic. Where is the best position to install the loop, and what kind of loop would be preferable? I have one free triode available (V2B), but still room on the chassis for additional tubes. I'm not really familiar with FX loops and limited knowledge, but if I understood well a signal coming from a cathode follower would be a good spot for FX loop?
Best regards
Dominic
Re: Hiwatt DR103 FX loop
« Reply #1 on: August 05, 2020, 06:28:10 am »
https://store.metropoulos.net/collections/amp-mods/products/zero-loss-fx-loop-board-only
This may be of interest to you?
That schematic looks like some variation of a "bootstrapped" cathode follower?  I am not sure I've ever seen that in a schematic before? And it looks like it may have some type of local negative feedback and/or a voltage divider. Unusual set up. Hopefully someone with more knowledge can explain it.
http://www.valvewizard.co.uk/dccf.html
I have no idea how to advise you on trying to use the CF with the unused triode as an active FX loop?   I probably would try the Metro FX loop after the master volume pot prior to the next triode's grid (V3-7)
« Last Edit: August 05, 2020, 06:39:35 am by tubenit »
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #2 on: August 05, 2020, 01:29:58 pm »
Here are a couple of ideas to kick around:
Offline 2deaf
« Reply #3 on: August 05, 2020, 01:43:57 pm »
V3, pins 1, 2, 3 is just setting the DC voltage for the LTP grids.  The DC voltage at pin 6 is too high for direct coupling to the LTP grids because it would make the voltage drop across the tail resistor too large thereby decreasing the available output voltage swing of the LTP.
« Reply #4 on: August 05, 2020, 02:11:21 pm »
Here's some more ideas (from Merlin Blencowe's 1st pre-amps book)
« Reply #5 on: August 05, 2020, 07:35:58 pm »
You want to figure a level-diagram so you don't smoke the inputs of your loop effects.
You want to define impedances low enough that it isn't fussy what effects you use.
Offline SoundCity85
« Reply #6 on: August 07, 2020, 06:05:15 am »
Thank you all for the feedback. I have some things to look into now. It seems on first sight that the FX loop directly after the treble pot is the easiest way to go.
Offline SoundCity85
« Reply #7 on: August 07, 2020, 06:06:34 am »
Hi 2deaf,
Thank you. Where did you obtain these schematics from?
Best regards Dominic
Offline 2deaf
« Reply #8 on: August 07, 2020, 03:43:45 pm »
Hi 2deaf,
I created them myself.  Here is one with a bypass switch.
Offline SoundCity85
« Reply #9 on: August 08, 2020, 07:51:14 am »
Hi 2deaf,
That looks great. How would you perceive the 10k pot? As an internal or external component?
Offline Latole
« Reply #10 on: August 08, 2020, 01:32:44 pm »
v
I must be external.
Offline SoundCity85
« Reply #11 on: August 09, 2020, 08:55:08 am »
Ok. So we have "in" and "out", a level control pot of 10k and a double on-on switch in the back to create a true bypass. I'll go for it
Offline 2deaf
« Reply #12 on: August 10, 2020, 10:33:21 am »
I would mount it so that it can be accessed externally just like the other control pots.
Offline Williamblake
« Reply #13 on: August 10, 2020, 10:40:11 am »
And so do i. And don't just say this just to get an even number of triodes.
Offline SoundCity85
« Reply #14 on: August 11, 2020, 09:27:52 am »
thank you for the advice. this forum is very supportive
a question popped in my mind when looking at the schematic. what would happen if you jumper send and return? will the V2 triode increase overall gain, or does it only recover what is lost in this loop?
« Last Edit: August 11, 2020, 09:39:07 am by SoundCity85 »
« Reply #15 on: August 11, 2020, 11:56:58 am »
That would be completely dependent on the fx send control setting.
I think it would be an improvement to insert a small resistor between the bottom of that pot and 0V. So as to avoid the signal being accidentally muted by an inadvertent knock of the send control.
Offline SoundCity85
« Reply #16 on: August 11, 2020, 12:37:53 pm »
What would you consider small? 1k or something like that?
Offline 2deaf
« Reply #17 on: August 11, 2020, 03:06:55 pm »
The loop has a maximum gain of 1.3 from treble to master volume with a typical 12AX7.
Offline 2deaf
« Reply #18 on: August 11, 2020, 03:19:01 pm »
I wouldn't go any larger than that.  I originally designed it with a 2.2K, but then I decided that I had better build the DR103 stage with the tone stack just to see what signal levels were possible.  I was surprised by the peak voltages that made it through that stack.  I removed the 2.2K because it was possible to exceed 0.5Vp with the Send Level at minimum.
Offline SoundCity85
« Reply #19 on: August 12, 2020, 03:00:43 am »
Ok, perhaps bring it down to 500 then? I only have a 10k log pot laying around. Would that also do the job?
« Reply #20 on: August 12, 2020, 09:13:15 am »
They should be fine, but as it's a log pot, you may need to turn it up past halfway.
Offline SoundCity85
« Reply #21 on: August 12, 2020, 09:31:45 am »
Thanks. In the end found a linear 10k CTS that measures fine. By the way, what is the reasoning behind the 4M7 going to ground?
« Reply #22 on: August 12, 2020, 10:50:27 am »
It mitigates ‘pops’ when the bypass switch is flipped.
Without it, in bypass mode, both of the cap’s plates will charge up to the tube’s plate voltage. When the loop is re engaged, that charge will create a momentary voltage spike in the next stage’s grid circuit.
Offline SoundCity85
« Reply #23 on: August 13, 2020, 04:57:56 pm »
All done. Testing is for tomorrow. Hopefully didn't make any mistake wiring the jack sockets, that's still difficult for me to grasp. Wasn't really sure how or where to ground, so I connected to my central ground buss after V2A and connected everything on that ground wire
« Last Edit: August 13, 2020, 05:01:49 pm by SoundCity85 »
Offline SoundCity85
« Reply #24 on: August 14, 2020, 03:40:35 am »
Works like a charm!
« Reply #25 on: September 08, 2020, 04:35:07 pm »
The one at the left on the bottom looks convenient. I wonder how the recovery stage is biased without a grid resistor?
« Reply #26 on: September 08, 2020, 04:58:26 pm »
The dc path between grid and cathode goes via 1M feedback resistor, load resistor, 1k5 cathode resistor.
« Last Edit: September 08, 2020, 05:03:16 pm by pdf64 »
« Reply #27 on: September 08, 2020, 05:52:03 pm »
Thanks for pointing that out. So the load would be 220k if you put this before the master volume in a DR103?
« Reply #28 on: September 08, 2020, 06:27:46 pm »
Sorry, yes, thanks for pointing that out!
« Reply #29 on: September 11, 2020, 06:24:08 pm »
Yet another question: the send has a 100uF capacitor or did i read that wrong? Would a 70V polarized Frolyt  cap do? Dont other effect loops use 1 to 10uF? I dont mind big caps but this is an odd value, isnt it?
« Last Edit: September 11, 2020, 06:57:46 pm by Williamblake »
« Reply #30 on: September 11, 2020, 07:48:16 pm »
It's a cathode bypass cap. 25 volt rating is fine.
« Reply #31 on: September 12, 2020, 02:29:30 am »
Sorry, i should have marked it in the picture right away. 100uF is a lot for a non polarized cap?
« Reply #32 on: September 12, 2020, 03:55:04 am »
That 100µF is also a polarized electrolytic. But since it's connected to a cathode follower it will need to be a higher voltage rating.
« Reply #33 on: September 12, 2020, 04:03:20 am »
Thanks.  As this cap is seeing one fifth of the cathode voltage i assume a 70V cap will do fine.
« Reply #34 on: September 12, 2020, 04:31:39 am »
100uF seems way higher than necessary to feed a 10k load from a roughly 8k source impedance - may be an error?
I think about 1uF would be more appropriate, with the benefit that a film type cap could be used.
The rule of thumb I remember reading in a vintage electronics mag is that with an audio amp using RC coupling between several successive stages, for minimal bass rolloff, each interstage C x R should equal at least 10, where C is uF and R is kohms. That works out to a corner freq of about 16Hz.
« Last Edit: September 12, 2020, 06:51:10 am by pdf64 »
« Reply #35 on: September 12, 2020, 02:55:02 pm »
100uF is in Merlin’s book. He recommends 63V for that part.
10 or 22uF will be fine.
« Reply #36 on: September 13, 2020, 02:16:27 am »
Thanks for checking on this, unfortunately i cant find my copy right now.
Offline wavley
« Reply #37 on: September 03, 2025, 03:43:24 pm »
Sorry to dig this one up.
I like the version of this that's simple basically interrupting the signal path, I also see a version around with the unused triode as a makeup gain stage.  I usually use that triode as a plate mixer.  I never really use effects loops and would like to keep my knob and switch count down.
Does this amp really even need make up gain? How has the super simple version worked for the folks that tried it.  Would I be better off ditching my plate mixer in favor using that triode's cathode to drive my send?
Thanks for your input.
