September 15, 2026, 05:49:05 pm
Hoffman Amps Forum image Author Topic: squeal  (Read 4287 times)
Offline isaac_teller
squeal
« on: August 06, 2020, 09:46:14 am »
Hello. I built a DIY clone of a Fender Deluxe reverb. after powering up there was a high-pitched squeal. I switched tubes, reversed output leads but the squeal persists. I removed V1 and the squeal is still there. If I turn the master down(Frondelli master volume) it cuts off the squeal. Any suggestions of what to try next?
Re: squeal
« Reply #1 on: August 06, 2020, 10:18:29 am »
Re: squeal
« Reply #2 on: August 06, 2020, 10:28:48 am »
When you say you switched tubes,  did you change ALL the tubes for known good ones?
What are the voltages?  What do you have the tubes biased at?
Can you post a hi-rez picture of the chassis interior?
Did you try disconnecting the NFB?
Did you try pulling one tube at a time and also jumpering over gain stages?
with respect, Tubenit
Re: squeal
« Reply #3 on: August 06, 2020, 11:06:54 am »
Yes, I changed all the tubes for known good ones. I will check voltages and post later. As for a picture, I don't have a smartphone, I'll have to ask a friend to photograph.
Re: squeal
« Reply #4 on: August 06, 2020, 11:12:29 am »
does the amp have NFB?, if so, disconnect and see
Re: squeal
« Reply #5 on: August 06, 2020, 11:49:41 am »
I also disconnected the NFB. Didn't help.
Re: squeal
« Reply #6 on: August 06, 2020, 12:11:35 pm »
Please provide a link to the schematic/layout you used. Also provide some info on the frondelli master volume. Maybe even remove that frondelli to see if it is the problem.
Pull the PI tube. It's the 12AT7 closest to the 6V6s. Squeal stop?
Re: squeal
« Reply #7 on: August 06, 2020, 03:37:39 pm »
