September 16, 2026, 05:22:15 am
Hoffman Amps Forum image Author Topic: Small PP amp build  (Read 5122 times)
Offline vampwizzard
    • Walbertedwards.com
Small PP amp build
« on: August 15, 2020, 12:55:20 pm »
Hey folks. Was interested in Tubenit's soldano 3-5 watt PP amp and got the iron.. a Basler BE class 2 PT of unknown power rating. Its 400V no center tap, 6.3V@4A and theres a 28VCT secondary that baffles me. OT is a 15W Hammond.
So, SS rect for sure due to a lack of center tap. Is there any use for that 28V winding? I also made the mistake of gigging that single channel ab763 (socially distanced and whatnot) and now wonder if the PT will handle an AB763 with reverb no trem or a D style.. with the 12AU7 output section from something like a Robrob mini. The heater circuit would be good to go. I can hit Basler up on Monday to get full specs for the high voltage winding mA capacity. Are there any schems floating around for that?
Re: Small PP amp build
« Reply #1 on: August 15, 2020, 01:14:11 pm »
400V AC rectified wants to be 560V DC. That may not be what you want.
Offline vampwizzard
« Reply #2 on: August 15, 2020, 01:33:02 pm »
 :l2: glad that it was not very expensive. Minor oversight huh? Got it on the chance it did have a center tap and they mis-listed it.
« Reply #3 on: August 15, 2020, 02:32:52 pm »
You could do a choke input filter and get the B+ down to about 360VDC.
Offline vampwizzard
« Reply #4 on: August 15, 2020, 02:38:28 pm »
I feel id have to dump so much voltage to get it into a territory for a 12A_7 based output from its original state that Id rather just use a proper transformer. That is an interesting, relevant bit of advice though. Thanks Sluckey.
« Reply #5 on: August 16, 2020, 05:15:21 am »
Not sure what this is referring to? Can you provide a link.  I haven't built anything like that.
Offline vampwizzard
« Reply #6 on: August 16, 2020, 07:06:10 am »
Probably a case of mnemonics gone wrong on my part. SoLow. https://el34world.com/Forum/index.php?topic=13438.msg127145
« Reply #7 on: August 19, 2020, 03:34:19 am »
perhaps confused about the author? TIMBO built a low-watt P-P version of the SLO. search for that?
« Reply #8 on: August 19, 2020, 03:39:20 am »
https://el34world.com/Forum/index.php?topic=24604.0
Offline vampwizzard
« Reply #9 on: August 19, 2020, 05:12:13 am »
Well.. that’s not the one I was thinking of but that’s exactly what I described!  :laugh: That’s awesome!
