September 19, 2026, 02:17:50 am
Hoffman Amps Forum image Author Topic: What to know before building a ReVibe?  (Read 7657 times)
Offline marks
« on: August 15, 2020, 03:27:28 pm »
I'd like to build a ReVibe (one of slucky's, weber's, or of course hoffman's), but am having second thoughts based on Weber's difficulty scale.
My experience, to help frame this:
  • pretty solid understanding of electronics, with tons of experience in digital
  • great at soldering. limited experience w/ high voltage, but can learn and take appropriate safety precautions
  • decent-to-good analog audio understanding through guitar pedals
  • but... close to zero tube experience, and a choppy understanding of amp circuitry
Weber states (my emphasis added):
Very Complex. Many stages that are interactive, multiple power supply filter poles, many tone and volume controls, effects, dense circuitry that is prone to noise and distortions if the wiring is not routed properly. Suggest the builder enlist the assistance of a veteran kitbuilder or electronics technician.
my question, said three ways:
  • What sorts of things might I need a technician for? "interactive" stages, but no documentation beyond a layout and schematic.
  • What information or steps are necessary beyond following the schematic and layout?
i.e. after following the layout and schematic, assuming good joints and no bone-headed mistakes (and/or finding and correcting any)... what tweaking, tuning, or modifications will I need and may not know how to do?
Thanks!
Re: What to know before building a ReVibe?
« Reply #1 on: August 20, 2020, 03:33:30 pm »
Well, if it doesn't work you'll likely need some help. Troubleshooting tube circuits requires some theory of operation knowledge. Voltage measuring, signal tracing, etc, and interpreting your measurements. This forum can/will provide a lot of help. Most problems on a new build are wiring errors, wrong component values, or sloppy workmanship. We've seen most of them.
You gotta have some chassis work skills unless you buy Weber's kit. Board work skills are nice to have also. You also need to know in which order to install certain things or which things to wire up first, especially important if you build this in a tweed style chassis. Having lots of pics of an actual build as it progresses from start to finish are nice to have too.
If you do it right there will be no need for any of this.
If you care about the quality of your workmanship, can read a schematic, and can follow a layout, there's no reason not to be successful. If you think you can put this together in one evening, or are sloppy, you will likely fail. Either way, this forum is a good place to share your project and you will find all the help you need.
Decide if you want to do it, choose a plan, and stick to it! Don't be jumping back and forth between Hoffman, Weber, and sluckey. Go for it! You can do it...
Offline marks
« Reply #2 on: August 20, 2020, 07:07:37 pm »
Thanks for taking time to outline all these factors.  I'm very confident I can handle all of that.
My biggest fear was that component values were just a starting point but needed to be individually calculated on a per build basis, or other undocumented wizardry was needed to get it working well beyond the schematic.
This all seems really straightforward so I'm looking forward to building it.
Thanks, and thanks for your well documented instructions too.
