September 16, 2026, 12:32:17 pm
Hoffman Amps Forum image Author Topic: 12AX7-as-Output Question  (Read 5811 times)
Offline neddyboy
« on: August 17, 2020, 06:16:40 pm »
Hello all! I recently acquired a small Masco intercom. It runs (or ran) on one 12AT7 tube and is/was a widowmaker circuit of sorts -- no PT. I stripped it and was left with an output transformer for the 12AT7, which apparently supplied enough power to run a 2.5" speaker, plus an impedance matching transformer. The intercom uses the speaker as a mic, and the second transformer makes that possible. I have 2 questions. 1: Could I use that tiny OT on the output of the Hoffman tube pedal preamp to drive a tiny speaker? Did the original intercom circuit push the 12AT7 harder than the Hoffman? Any feedback would be appreciated. 2: What could I do with the impedance matching transformer? It's an 8ohm speaker -- does that mean the input impedance is 8ohms? Any idea what the secondary impedance might be, going into a 12AT7?
Offline neddyboy
Re: 12AX7-as-Output Question
« Reply #1 on: August 17, 2020, 06:31:51 pm »
I think I answered my own question. The little OT sees 135V from the 12AT7. Holy moly, I hope I never see that much out of my Hoffman pedal! Follow on question: could I build a single-tube amp around this 12AT7 tube using this OT but safely, with a PT and a diode bridge?
« Reply #2 on: August 17, 2020, 06:44:14 pm »
the easy answer is No, to get to Yes, you'll expend way more energy than you''ll get back  :icon_biggrin:
« Reply #3 on: August 17, 2020, 11:36:09 pm »
Amps is amps. The whole thing "is" a guitar amp, dressed for intercom duty.
As you say, a g-amp demands isolated wall-power. A guitar won't drive the low-Z transformer but will drive the volume control. The speaker/mike is very likely 45 Ohms for better mike-action on very long (and cheap) wiring. You can series several normal speakers to get near 45 Ohms. Or you can use the 22k:4 transformer for Fender reverb.
Offline Latole
« Reply #4 on: August 18, 2020, 03:24:50 am »
For isolating transformer, I often use two low power transformers find at thrift store for cheap or surplus electronic store
Here two 120  to 24 volts used to make one isolating transformer
120 ( from wall outlet ) to 24 at secondary to second transformer secondary 24 to 120 volts to amp circuit
« Last Edit: August 19, 2020, 05:45:15 pm by Latole »
Offline neddyboy
« Reply #5 on: August 19, 2020, 05:28:36 pm »
I haven't come across a widowmaker amp (so far) that has been worth the trouble of an isolation transformer. This thing was just a bunch of fishy low-rent looking stuff, including a very weathered 20 watt resistor, an all-metal case (zap), and a few others. I disassembled it! Now I have some parts to fool with.
