September 17, 2026, 10:40:40 pm
Hoffman Amps Forum image Author Topic: marshall lite 2 preamp / 6sn7gtb power tube  (Read 5892 times)
Offline Mehfuzhoss
« on: August 20, 2020, 08:44:43 pm »
Hello,
I am back to this forum for a build that I am planning. I built a ax84.com 4 4 0 (3x 12ax7 and 1x 6sn7gtb) and not liking the amp. I want to reuse the PT OT and the power tube 6SN7GTB and build a marshall preamp based amp if possible. I really like the lite ii circuit.
The PT is 269JX - 500VCT with 69ma
OT is 125C 8 watt output; Primary Impedance:   1.2 kOhms to 25 kOhms; Secondary Impedance:   1.5 Ohms to 15 Ohms
any idea or direction is appreciated
Re: marshall lite 2 preamp / 6sn7gtb power tube
« Reply #1 on: August 21, 2020, 07:10:33 am »
Posted in wrong board.... moving
« Reply #2 on: August 21, 2020, 07:40:28 am »
This mini-bassman and marshall idea may prove useful to you.  There is a schematic and layout. I have NOT built one.
https://el34world.com/Forum/index.php?topic=18481.0
Offline Mehfuzhoss
« Reply #3 on: August 21, 2020, 03:05:32 pm »
Thanks a lot.
Offline Mehfuzhoss
« Reply #4 on: August 22, 2020, 04:44:41 pm »
The 269JX PT doesnt have a center tap. (The green yellow wire to the 180k resistor in the attached image is the CT. )
Will i leave this connection? Will it cause him or buzzing? If so how can i create an artificial tap.
Help!
Online sluckey
« Reply #5 on: August 22, 2020, 04:56:00 pm »
Connect a 100Ω 1/2w resistor to a 6.3VAC filament pin of the closest (or most convenient) tube socket. Connect another 100Ω 1/2w resistor to the other filament pin of the same socket Connect the free ends of those two resistors together and then connect a wire from the junction of those resistors to that point on the board where the green/yellow wire is connected. I suggest using a terminal strip to secure the ends of those resistors and wire.
Offline Mehfuzhoss
« Reply #6 on: August 23, 2020, 04:41:26 am »
PT spec: 269JX 50VA 115AC 60hz, 500V C.T. @ 69ma. 6.3V @ 2.5A . can I run the rectifier tube with the same 6.3V winding?
I need to power 3 12axy7, 1 12au7 and rectifier ez81. can the PT handle these load with same 6.3V tap?
thanks
Offline Mehfuzhoss
« Reply #7 on: August 23, 2020, 04:50:59 am »
is the choke 5 Henry 50 milliamp a must for the JTM45 2 watt build? Will a resistor do the trick? if so, what size resistor would you recommend and where should i wire it in the layout!
Thanks.
Online sluckey
« Reply #8 on: August 23, 2020, 06:03:56 am »
yes
Very easy to do this yourself. Look up each tube. Write down the filament current requirement. Add 'em up. Start here...
     http://tdsl.duncanamps.com/tubesearch.php
The choke is very important to the sound of a JTM45. Probably not so much to your project. I'd start with a 1K/3W and experiment until you have the B+ voltages like you want.
Offline Mehfuzhoss
« Reply #9 on: August 23, 2020, 06:48:10 am »
Online sluckey
« Reply #10 on: August 23, 2020, 06:54:30 am »
yes
Offline Mehfuzhoss
« Reply #11 on: August 23, 2020, 05:29:32 pm »
I have a F & T 100uf 500V cap, the build calls for two 47uf. Is there a way I can use the 100uf ?
« Reply #12 on: August 23, 2020, 05:47:14 pm »
post 4 shows a 40/20/20/20  :dontknow:
if you're doing the PS, 2 47uf will have a resistor between 'em, a single 100 won't
Online sluckey
« Reply #13 on: August 23, 2020, 07:48:31 pm »
No. You must follow the plans exactly.
