September 17, 2026, 09:32:54 pm
Hoffman Amps Forum image Author Topic: Power Transformer for Laub Engeering Model 26  (Read 5704 times)
Offline jamesedmunda
« on: August 22, 2020, 08:45:38 am »
I need a power transformer for a Laub Engeering model 26. Kind of a Magnatone 260 clone.
It looks like a Fender Hot Rod transformer would work.
 Doesa anyone see any problems, here's the specs.
Fender Original Hot Rod Deluxe Power Transformer. Equivalent to #036958.
Specifications Primary 120 VAC @ 60 Hz (Black - White) Secondary 1 (Red - Red) 495 VDC unloaded, 440 VDC @ 65.7 mA DC, 388 VDC @ 200 mA DC Secondary 2 (Brown - Brown) 53.6 VAC @ 1.58 A AC Secondary 3 (Green - Green) 6.6 VAC @ 3.75 A AC
Fender part number: 003-6958-000
 Mojotone has one with 4 amps on the Heater winding, would that be a better fit.
 Thanks again James
« Last Edit: August 22, 2020, 02:20:48 pm by jamesedmunda »
Offline vampwizzard
    • Walbertedwards.com
Re: Power Transformer for Laub Engeering Model 26
« Reply #1 on: August 22, 2020, 11:10:00 am »
You may be a little high on the B+ if you dont use the 48V winding otherwise it appears you have enough current available for the tubes.
Offline Latole
« Reply #2 on: August 22, 2020, 11:26:24 am »
Did you check how much current tubes's heater need ?
Transformer specs are 6.6V at 3.75 amps
Offline vampwizzard
« Reply #3 on: August 22, 2020, 12:40:36 pm »
looks like those 6CG7's take .6A per tube. You're looking at ~4A of heater current.
« Reply #4 on: August 22, 2020, 02:55:58 pm »
another option.
https://www.edcorusa.com/xpwr021
« Reply #5 on: August 22, 2020, 03:06:33 pm »
Thanks for the reply Pete.
 Do you think the B++ is high enough the schematic shows 390 volts while the Edcor  transformer is only showing 290volts.
 Thanks James
« Reply #6 on: August 22, 2020, 03:44:27 pm »
 Thanks James
290VAC will make about 410VDC unloaded. Probably be just about right with load. But, you've been looking at laydown type transformers. Can you use a standup type transformer?
« Reply #7 on: August 22, 2020, 05:03:19 pm »
Schem is DC Volts, Edcor sells you AC Volts. Not the same. Counting on thumbs, 400V DC might be 282V AC. Or what DL said. More VAC if it was a tube rectifier, but it isn't.
A "5F6a Bassman" PT will work out to around 400VDC (with different rectifier connection!) but is probably over-kill (more current than you need).
« Reply #8 on: August 23, 2020, 04:39:18 pm »
Thanks Guys,
 I've ordered the Edcor.
James
