September 18, 2026, 04:35:08 am
Hoffman Amps Forum image Author Topic: buzz on volume control only at medium settings  (Read 4203 times)
Offline isaac_teller
« on: September 03, 2020, 01:09:48 pm »
Hello. What can be done to stop the buzzing when the volume knob is between 4~8? Other than that the amp is quiet. Thank you.
« Last Edit: September 03, 2020, 01:12:29 pm by isaac_teller »
Re: buzz on volume control only at medium settings
« Reply #1 on: September 03, 2020, 01:21:58 pm »
Have you eliminated it being due to a buzzy tube, ie the stage after the vol control?
« Reply #2 on: September 03, 2020, 01:25:24 pm »
Sometimes a capacitor going into the pot can leak voltage causing noise.
We might be able to help you more if you shared a schematic and a hi-rez photo of the inside of the amp chassis.
with respect, Tubenit
« Reply #3 on: September 03, 2020, 01:41:58 pm »
I tried several tubes, didn't help. I'll try changing the cap.
« Reply #4 on: September 03, 2020, 02:39:20 pm »
Crap is leaking into the wire from the pot wiper. Full-up the crap is absorbed by whatever drives the pot; and full-down of course the crap is absorbed by ground. But "in the middle" you have a high impedance to either end. The wire is an effective antenna for any crap in the chassis, especially crap near that wire.
So what does the wiper-wire run near?
