September 08, 2026, 02:39:25 pm
Hoffman Amps Forum image Author Topic: B15N Preamp DI layout  (Read 9467 times)
Offline Jatchley
  • i haven't been shocked yet.
« on: September 11, 2020, 09:32:16 am »
Howdy yall. i tried to read a schematic and draw a layout from what i read for the first time. i made this preamp. im not sure if it actually works. im still sourcing parts. i did change the 12au7 for a 6sn7. the schematic i found also didnt have a power section so i did my best at thinking what the power supply would be. id love any advice and help with any mistakes. it should be a neat little preamp.
*edit* someone on facebook said the coupling caps (..22) are on the wrong side of the plate load resistors. looking into that. ( turns out to just be on the schematic not the layout)
« Last Edit: September 11, 2020, 10:27:27 am by Jatchley »
Re: B15N Preamp DI layout
« Reply #1 on: September 11, 2020, 11:55:26 am »
Offline Jatchley
« Reply #2 on: September 11, 2020, 08:52:51 pm »
im also curious to exactly which OT i should get. any suggestions here?
Offline AmberB
« Reply #3 on: September 11, 2020, 10:41:54 pm »
From the schematic that you posted, it looks like you need an impedance matching transformer, the kind use to convert a low impedance microphone to a high impedance signal.  They work for both inputs and outputs.
Offline xm52
« Reply #4 on: September 15, 2020, 07:10:15 pm »
Offline Jatchley
« Reply #5 on: September 25, 2020, 11:51:07 pm »
hey there. the box is built... but im having some hum issues on the XLR out. the 1/4in out works great! so i went with an edcor xsm 15k:600 and i have pretty significant hum and low levels out. the 1/4 in out is much cleaner and higher level. the edcor has a CT for both primary and sec. the primary CT reduced about half of the hum and the secondary CT does nothing when grounded. i have the xlr ground pin to a ground lift switch run straight to the chassis. ive tried lifting all the grounds from the XLR and OT with no difference. i have also tried switching the OT primary and no change. any ideas?
*edit* ALL IS GOOD SOLVED THE PROBLEM! accidentally switched up pins 1/2 on xlr. swapped em and the box is silent.
« Last Edit: September 26, 2020, 03:25:12 pm by Jatchley »
Offline tazwolf
« Reply #6 on: September 22, 2022, 09:14:43 am »
I am going to build this preamp. I wonder if someone can give me some help. I will not be able to get hold of a suitable DI output transformer for a while but I want to use the instrument out until i do, is it possible to use the the pre without the 600R DI out? Do I just leave it unconnected or do I need to put a resistor in its place temporarily and if so what value resistor should I use?
Also if anybody has built this and has any advice in addition to what is already written here then I would be very grateful.
« Reply #7 on: September 22, 2022, 09:27:11 am »
Just build everything except the transformer. No need for a temporary resistor.
