September 14, 2026, 06:49:18 pm
Hoffman Amps Forum image Author Topic: MU metal foil  (Read 5316 times)
Offline Leevi
    • Rikstone
MU metal foil
« on: September 14, 2020, 12:01:21 pm »
I have had several time issues where the power transformer causes hum via reverb tank.
Has anyone tried MU metal shields for protection and how the protection should be done?
/Leevi
Re: MU metal foil
« Reply #1 on: September 14, 2020, 12:34:51 pm »
I searched "metal shielding" here and got this, you can read it, lunch is ready  :icon_biggrin:
https://el34world.com/Forum/index.php?action=search2
Offline Latole
Re: MU metal foil
« Reply #2 on: September 14, 2020, 12:39:50 pm »
I have no try this. The only amp I have to repair with this issue, I just move a bit reverb tank and no more hum.
Which amp did you talking about ?
 What is MU? Multi Usage metal tape ? Kind of air duct tape ?
Transformer is already in a grounded steel case
Offline Latole
Re: MU metal foil
« Reply #3 on: September 14, 2020, 12:40:44 pm »
Not post there, noting
Offline Leevi
    • Rikstone
Re: MU metal foil
« Reply #4 on: September 14, 2020, 01:07:37 pm »
The magnetic field of the PT causes the hum and if there is no room to move the tank in the  cabinet the only way is to protect the tank (or PT). Normally it helps a bit if the tank output is placed in the other end as the PT. I see this as a more general issue especially in heads.
https://en.m.wikipedia.org/wiki/Mu-metal
/Leevi
« Last Edit: September 14, 2020, 02:18:00 pm by Leevi »
Offline Williamblake
Re: MU metal foil
« Reply #5 on: September 16, 2020, 12:11:27 pm »
I had the same issue abd put a 2mm metal plate between transformer and tank, that solved it. The plate had to be screwed on tight or it would rattle like hell. I dont think foil will help.
Re: MU metal foil
« Reply #6 on: September 16, 2020, 02:46:48 pm »
Foil made from MU metal will be about as useful as tinfoil hats
Re: MU metal foil
« Reply #7 on: September 16, 2020, 05:23:29 pm »
 :laugh:
I scraped out the last of my Mu metal shims we used in MR, ~ 30lbs.  I told the scrapper "It's Mu metal, do I get a better price";  He replied "If you want it to be my metal, stick it in the iron pile, n that's what I'm paying"
ah well, one last thing to trip over.
Offline Leevi
    • Rikstone
Re: MU metal foil
« Reply #8 on: September 16, 2020, 11:16:20 pm »
I have tried using  different metals like, steel, aluminium, copper etc. but not that thick material.
The magnetic field can be protected by using  MU metal, sometimes with steel but it probably depends on its composition?
BTW. I have learned that never use toroidal PT if you have a reverb in your amp.
I scraped out the last of my Mu metal shims we used in MR, ~ 30lbs.  I told the scrapper "It's Mu metal, do I get a better price";  He replied "If you want it to be my metal, stick it in the iron pile, n that's what I'm paying"ah well, one last thing to trip over.
MU metal is damn expensive
/Leevi
Re: MU metal foil
« Reply #9 on: September 17, 2020, 07:35:40 am »
ya, the box cost $1,000's in the '90's, but time moved on, and the 'ol guy I sell to only has so many piles  :icon_biggrin:
