September 14, 2026, 07:47:06 pm
Hoffman Amps Forum image Author Topic: Hi/Lo input ground wiring  (Read 9260 times)
Offline daveyajd
« on: September 16, 2020, 09:16:12 pm »
I have never put 2 inputs on any previous amps so I’m a bit confused. Looking at Doug’s hookup info: I get the cliff jack wiring, but the switchcraft wiring seems weird just because it doesn’t show any connection to the low jack ground lug. The shunt and ground are connected on High. Do I connect the low ground to the high ground and then run a wire to my input end ground lug?
Aaron
« Last Edit: September 16, 2020, 09:31:07 pm by daveyajd »
Re: Hi/Lo input ground wiring
« Reply #1 on: September 16, 2020, 09:28:42 pm »
I have never put 2 inputs on any previous amps so I’m a bit confused. Looking at Doug’s hookup info: I get the cliff jack wiring, but the switchcraft wiring seems weird just because it doesn’t show any connection to the low jack ground lug. The shunt and ground are connected on High, the tip and shunt on the low. Do I connect the low ground to the high ground and then run a wire to my input end ground lug?
Look closely. The Hi jack doesn't have any ground wire either. Hoffman relies on the jack bushing/nut to provide chassis ground for both jacks. Fender does the same.
Offline daveyajd
« Reply #2 on: September 16, 2020, 09:36:58 pm »
Ok. So I don’t need any ground wire to my ground buss? Does having one affect anything? Because I think I have always run a ground wire from my input jack. Grounded in two places?
Aaron
« Reply #3 on: September 16, 2020, 09:45:36 pm »
Just terminate your ground buss at the input jack sleeve/ground lug. Look here...
     https://el34world.com/charts/grounds.htm
Offline daveyajd
« Reply #4 on: September 16, 2020, 10:50:02 pm »
Thank you so much Sluckey! So why does the output jack get wired to the power side chassis ground? Wouldn’t it be grounded at the jack as well?
Aaron
« Reply #5 on: September 16, 2020, 11:02:50 pm »
Aaron
Simple answer is the output jack is DC-isolated from the amp's power supply ground returns
Offline daveyajd
« Reply #6 on: September 17, 2020, 12:13:15 am »
Awesome. Thank you both.
« Reply #7 on: September 17, 2020, 06:15:16 am »
Not so if there is a NFB loop from the OT secondary.
Offline daveyajd
« Reply #8 on: September 17, 2020, 08:41:23 am »
So output still needs to be grounded in that case? At the same spot or somewhere else?This build is a JTM variant so it seems to have NFB.
Aaron
« Reply #9 on: September 17, 2020, 08:51:06 am »
Look at the link I provided.
Offline daveyajd
« Reply #10 on: September 17, 2020, 09:20:26 am »
I’m sorry. I don’t see any reference to NFB grounding on that drawing.
Aaron
« Reply #11 on: September 17, 2020, 09:29:34 am »
Where is the speaker output grounded?
Offline daveyajd
« Reply #12 on: September 17, 2020, 09:40:04 am »
Yes I got that the first time around. That is where I have always grounded my output. I thought your response to tubeswell was referencing a different ground. It seems it was just clarifying the “DC isolation” when including a NFB. Thanks for all your guidance.
Aaron
« Reply #13 on: September 17, 2020, 12:10:12 pm »
Okay so the not-so-simple answer is the secondary is galvanically isolated from the amp’s power supply signal ground (that is) connected to the primary - but for the NFB. However, any hum (that might be ‘reverse-sourced‘ from the NFB output in the preamp) is a low current source working into a high load impedance. And so noise from such a source will be much less of a factor than noise that is already inducted through the OT from Pr to Sec. So the best place to clean up ground hum is the signal ground, and if doesn’t matter if you ground the OT secondary at the output jack sleeve
