September 16, 2026, 10:21:35 pm
Hoffman Amps Forum image Author Topic: Twin Reverb 100 watts, volume pots scratch resolve  (Read 5039 times)
Offline Latole
« on: September 22, 2020, 05:52:08 am »
The solution has been found. Filter caps
My approach
Problem at the origin; the volume knobs are noisy when turning them and on both channels.
The master volume is correct
1- Contact cleaner; without success (deoxit)
2- All the signal capacitors (coupling) are good and do not let the DC pass
3- New pots are only slightly better.
     I put the old ones back.
4- I intended to replace the old filter caps with F & T
      Once done; no more noise problem at the volume potentiometer
Moral of this story; always replace old filter caps as mentioned regularly
Schematic ;  https://el34world.com/charts/Schematics/files/Fender/Fender_twin_reverb_sf_100_schem.pdf
Offline Leevi
    • Rikstone
Re: Twin Reverb 100 watts, volume pots scratch resolve
« Reply #1 on: September 24, 2020, 07:42:19 am »
I have had the same issue sometimes with FMV tone stack. Thank you for sharing this.
/Leevi
« Last Edit: September 24, 2020, 08:45:30 am by Leevi »
Offline Latole
« Reply #2 on: September 24, 2020, 07:51:48 am »
I have had the same issue sometimes with FMV tone stack. The problem is caused by the DC even the caps are fine. Unfortunately I didn't find the reason.
/Leevi
Did you replace all filter caps ?
Offline Leevi
    • Rikstone
« Reply #3 on: September 24, 2020, 08:50:06 am »
No, I changed my previous response since you had a solution there. Sorry I did not properly read your message.
/Leevi
Offline Latole
« Reply #4 on: September 24, 2020, 10:13:53 am »
No,
/Leevi
New filter caps may fix the issue
