July 31, 2026, 06:35:54 am
Hoffman Amps Forum image Author Topic: Princeton Reverb: Loud humm independent of volume. Garbled sound.  (Read 4984 times)
Offline anteriorl5
Where to start? Hum started after about 15 minutes during practice.
Re: Princeton Reverb: Loud humm independent of volume. Garbled sound.
« Reply #1 on: September 24, 2020, 10:24:22 am »
Change tubes. Then bridge a test filter cap across each filter cap.
Offline anteriorl5
« Reply #2 on: September 24, 2020, 01:41:50 pm »
Tubes all good. Filters good, but all the bypass caps are original as is the bias cap. Sounds has to be coming from the power section I'm assuming. Removing preamp tubes has no effect.
Offline Latole
« Reply #3 on: September 24, 2020, 02:24:56 pm »
How do you test filter caps to say they are good ?
Hum may come also from bias caps or from one defective power tube.
Hum is there with no preamp tubes ; You have now only Power tubes with B+ voltage and bias voltage. Look more a power tube issue.
« Last Edit: September 24, 2020, 02:29:35 pm by Latole »
« Reply #4 on: September 24, 2020, 02:39:46 pm »
...bridge a test filter cap across each filter cap.
« Reply #5 on: September 24, 2020, 02:57:45 pm »
... all the bypass caps are original as is the bias cap...
A bad bias cap can make an amp hum
Offline anteriorl5
« Reply #6 on: September 24, 2020, 04:16:01 pm »
Okay so I bridged the filter caps and one WAS open. Hum mostly went away. Ordering a new can cap and going to replace all the bypass caps and the bias cap as well. It was a fairly new can cap so sort of surprising...thanks for the help!
