August 29, 2026, 05:54:08 pm
Hoffman Amps Forum image Author Topic: How loud is a Firefly amp supposed to be? Is this normal?  (Read 4262 times)
Offline DrewB
« on: October 05, 2020, 03:15:18 pm »
I just completed a Firefly Rev 3 build (omitted the Standby switch) and am thinking it should be louder when it's all the way up. I can talk over it running through a Celestion Greenback, though it's almost at conversation level.
Plate voltages (12AU7): ~ 240VDC
Cathode voltage drop: ~ 22VDC
Cathode resistor: 470R
Power transformer is Hammond 269EX and output transformer is Hammond 125A.
Re: How loud is a Firefly amp supposed to be? Is this normal?
« Reply #1 on: October 05, 2020, 03:59:35 pm »
my math is coming up ~ 10W of heat
2 tubes?
believe the tube is ~3W max?
« Reply #2 on: October 05, 2020, 04:10:18 pm »
A Firefly may not be over 1 Watt clean audio output. But in a Greenback that should be over 95dB SPL in a home room, and that's SHOUT, not conversation.
The Hammond 125A has way too many wires to connect different ways.
Offline DrewB
« Reply #3 on: October 05, 2020, 05:30:43 pm »
Bonehead mistake: I missed a ground to the grid on V3b and didn't catch it on my first check-through.
« Last Edit: October 05, 2020, 08:15:36 pm by DrewB »
