September 09, 2026, 04:09:54 am
Hoffman Amps Forum image Author Topic: Vadis To Dumble #183  (Read 13889 times)
« on: October 07, 2020, 05:09:25 am »
Hi guys, Looking for something to do :eyeroll
I have had a Vadis four input 60w PA on the shelf for sometime now so it's time to PIMP my amp.
I had not even opened it up to see it's guts, but now that I have it's originality is long gone.
Lots of holes in the front panel, three peramp sockets on the upper chassis and phase inverter power tubes on the lower.
Power transformer is not original and the A&R if the model number is correct(faded of sticker but the last three numbers 892) the only PT that I can find with those numbers is a 1892.
The rectified volts are about right for a pair of EL34 @60w but the mAs are a bit low.
I have not built a Dumble so this should be fun
Re: Vadis To Dumble #183
« Reply #1 on: October 07, 2020, 06:41:31 am »
I will be following this with great interest!  Should be a fun build to attempt.
My understanding is that layout is critically important for the Dumble tone. Having said that, I certainly think it's possible to
have a good layout without following the Dumble layout.  I don't know of anyone who built one with a split chassis, but I don't see why one couldn't do that successfully?
I have found orientation of the caps to be significant in reducing noise in my dumblish inspired amps, so I'd recommend taking the time to do that.
« Reply #2 on: October 07, 2020, 02:49:59 pm »
Thanks mate, I have not done the cap orientation thing before, but will do with this one.
The chassis are from a head cab, so wire runs will be short.
« Reply #3 on: October 11, 2020, 02:08:09 am »
Hi guys, After much thinking I've worked out how I'll do this...
Chassis striped and cleaned
Lots of holes to work with.
Need to get some parts in.
« Reply #4 on: October 20, 2020, 05:18:33 am »
Hi guys, A little progress..
« Reply #5 on: October 20, 2020, 07:56:13 am »
Looking good!   :thumbsup:
Thanks for sharing this build thread!  Looking forward to your review of the amp and maybe a sound clip or YouTube.
« Reply #6 on: October 23, 2020, 03:48:16 pm »
Relays in
« Reply #7 on: October 24, 2020, 05:24:28 am »
Hi guys, I bought some reverb boards off Tristin Collins some time a go,so I'm keen to see how they perform
I don't fully understand how they are grafted into the circuit...
« Reply #8 on: December 06, 2020, 04:44:28 am »
Hi guys, I hate it when work slows the solder fumes.
« Reply #9 on: December 06, 2020, 01:06:28 pm »
Timbo,
Do you have a schematic with this, please?  I am understanding that you have a split chassis thing going on with preamp in one and the power amp in another?  Is this correct?
with respect, Tubenit
« Reply #10 on: December 11, 2020, 03:11:56 pm »
Hi T, Exactly
Work is slow on this one.
« Reply #11 on: October 11, 2024, 04:23:39 pm »
So a mate is looking for a DUMBLE
Wiring completed
The reverb was removed
Foot switchable PAB removed
« Reply #12 on: October 13, 2024, 05:35:16 am »
Cool project!  Thanks for sharing.
« Reply #13 on: December 27, 2024, 02:30:36 am »
Hey guys,
A bit of time in the shed between the feasting and family stuff.
Got a few bugs sorted and sounding good.
The replacement PT is only putting out 330v at Node "A" which is probably around 30w output
I'll tart up the head cab and possible build a 2x12 matching cab
« Reply #14 on: December 27, 2024, 05:37:11 am »
I love this project!!   :icon_biggrin:    Thanks for sharing!  Somewhere down the line IF possible and convenient, I'd love to hear some sound clips of this amp even if just recorded with a cell phone.  :thumbsup:
This has been a really innovative project.
« Reply #15 on: December 27, 2024, 02:53:56 pm »
Thanks T.
The Dumble's really have a different sound.
The overdrive is so smooth with lots of sustain and bark when you dig in.
My stunt guitarist loves them so I don't think it will be too hard to convince him to do a clip.
So far there is no excessive noise or hum due to the split chassis
« Reply #16 on: December 27, 2024, 03:27:46 pm »
stunt guitarist
meters n scopes are a techs tool box, but add in a stunt guitarist and you stand above the rest!
« Reply #17 on: December 29, 2024, 05:52:46 pm »
Hey guys,
I've got a problem
All was working well till the power tubes started to redplate.
Back on the bench and ...
Negative bias has a good range and is present at pin5 on the tubes socket
1ohm sence resistor connected to pins 1 and 8
Bias was set at -22 with approx. 70mAs at the 1ohm resistors and 330v at the plates, then within seconds the mAs rise to over 110mAs and the tubes start to redplate
Adjusting the bias has no effect on the rising mAs
This is a first for me  :dontknow:
« Reply #18 on: December 29, 2024, 06:22:46 pm »
Hey guys, I may have rumped the gun on this one.
Chucked another set of tubes in and all is stable
Offline bmccowan
  • Better builder than player
« Reply #19 on: December 29, 2024, 06:31:05 pm »
"rumped the gun" Timbo, is that one of those odd Aussie slangs?
Mac
John Prine
« Reply #20 on: December 29, 2024, 06:46:09 pm »
it's all that SUN he's enjoying, twitches the qwerty fingers
Make sure it's stable on the bench a couple hours
a shorted tube will mess up the bias, but so will a sketchy connection so bump it a few times while it's on the bench
« Reply #21 on: December 29, 2024, 07:36:01 pm »
Some more here
100 Most Common Australian Slang Words and Sayings
« Reply #22 on: December 31, 2024, 11:17:44 pm »
Hey guys
A few tolex repairs done to the head cab and put back together.
A faceplate will de designed
Speaker cab constructed and sanded ready for some tolex
I'll use these, made in the early seventies and has been said they sound similar to the greenback
The Etone brand speakers were used by many of the local builders at the time.
Great condition for 50+ years
