August 29, 2026, 07:29:07 pm
Hoffman Amps Forum image Author Topic: Elevated Heaters  (Read 3396 times)
Offline Cree
  • It's a Guitar amp not Rocket science.
Elevated Heaters
« on: October 12, 2020, 05:32:30 pm »
I did a search of this topic But did not find an answer that I was wanting. When do you elevate the heaters or why do you elevate them?? Do it on every amp you build or only Hi gain PP out put. Should you elevate the heaters on any build even if its low watt triode output, Single ended only or on Push Pull Hi gain?? Sorry for the double statement, trying to clarify myself.
Note to self: Do not Tic-off the Dentist before needed work, And do not Tic-off the Rectial surgen before needed surgery. Makes for Two V-bad weeks.
Re: Elevated Heaters
« Reply #1 on: October 12, 2020, 07:07:08 pm »
See section under ‘Heater Elevation’ on this link:
http://www.valvewizard.co.uk/heater.html
Offline trobbins
    • Tim's projects and info
« Reply #2 on: October 12, 2020, 08:22:09 pm »
More background detail is also provided in link - in particular pages 3-7:
https://www.dalmura.com.au/static/Hum%20article.pdf
Offline Cree
« Reply #3 on: October 13, 2020, 01:42:00 pm »
Thank you Guys for the links. I have been to the Wizards site many times. The other link is new to me. Looks like I will incorporate this into my next project.
