August 29, 2026, 07:29:58 pm
Hoffman Amps Forum image Author Topic: Two heater secondaries  (Read 7187 times)
Offline Vlada
« on: October 12, 2020, 06:05:35 pm »
Hi guys, I have a transformer that I plan using for my new build. Transformer has two heater secondaries, one of them is center tapped and I thought about using that one for tube heaters and other one, which isnt center tapped, for indicator lamp. My question is should I implement artificial center tap, or it doesnt matter since it will be only used for indicator lamp?
Re: Two heater secondaries
« Reply #1 on: October 12, 2020, 06:31:38 pm »
I like creating an artificial CT that will burn up before the PT
the indicator side just put 2 wires to 2 leads making sure they touch nothing else.
« Reply #2 on: October 12, 2020, 06:33:42 pm »
My question is should I implement artificial center tap?
no
Offline AmberB
« Reply #3 on: October 12, 2020, 08:06:27 pm »
Are both heater secondaries 6.3 volt?
Offline Vlada
« Reply #4 on: October 12, 2020, 08:43:15 pm »
Thank you for the answers.
Yes, both are 6,3
One is center tapped (3,15-0-3,15), other one is not (6,3-0)
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #5 on: October 12, 2020, 11:24:21 pm »
Sometimes a PT will have one heater winding for the power tubes and another heater winding for the preamps.  If you try to use the preamp heater winding for the entire amp, it may be under powered.
« Reply #6 on: October 13, 2020, 11:03:18 am »
What 2deaf said. One of the windings may’ve been a separate winding for a 6V rectifier and may only be rated for that, e.g. 1A. (and if this is the case here, it’s likely to be the winding without the CT)
Offline Vlada
« Reply #7 on: October 13, 2020, 12:32:15 pm »
6,3-0 is rated 500mA. My main concern is will it add noise because preamp is high gain. Is there going to be any diference in hum if I dont put artificial ct in use with that secondary?
« Reply #8 on: October 13, 2020, 12:54:55 pm »
If you use the winding for a signal tube filament, then you should put the ground reference resistors in, otherwise you have no h-k voltage reference for the tube, and it will probably hum quite noticeably.
Offline Vlada
« Reply #9 on: October 13, 2020, 12:56:26 pm »
I thought using it for pilot light  :dontknow:
« Reply #10 on: October 13, 2020, 01:06:01 pm »
It can only support 1 preamp tube, eg 12AX7.
Heaters that aren’t balanced or smoothed dc will cause hum.
Offline Vlada
« Reply #11 on: October 13, 2020, 01:49:09 pm »
I think my question is misunderstood  :BangHead: I wouldnt use that secondary for any of the tubes, just for the pilot light
« Reply #12 on: October 13, 2020, 01:57:14 pm »
Haha, unless the wiring to the lamp runs near the preamp circuit, they can be regarded as completely separate things.
Sono need / benefit for any type of 0V reference on it.
« Reply #13 on: October 13, 2020, 02:57:49 pm »
I thought your intentions were perfectly clear. Hence my very short answer in reply #2.  :wink:
« Reply #14 on: October 13, 2020, 03:13:38 pm »
 :laugh:
yup, I understood, just more coy about it in reply #1
