August 29, 2026, 07:22:51 pm
Hoffman Amps Forum image Author Topic: Traynor YCV 40 lowB+  (Read 3716 times)
Offline jamesedmunda
« on: October 15, 2020, 04:33:03 pm »
Got a Traynor YCV 40 with a board #M581-4.00
I'm getting 160vdc on output transformer center tap with the tubes in and 315vdc with the tubes out.
 I get 220vdc to ground on pins 4 and 9 on all 3 12ax7 tubes. I've replaced Q1,Q8,Q10 and Q12 whats left. The power transformer tests good and I get the the same readings with the output transformer disconnected.
Can any one point me in the right direction.
Here's a link to the manual.
TIA James
https://www.thetubestore.com/lib/thetubestore/schematics/Traynor/Traynor-YCV40-Schematic.pdf
Re: Traynor YCV 40 lowB+
« Reply #1 on: October 16, 2020, 10:55:51 am »
This makes no sense. Therefore it is not wired right. I would inspect ALL grounds. Broken wires, rusty screws, tarnished connectors.
Offline JustMike
« Reply #2 on: October 16, 2020, 05:48:06 pm »
Reflow the PCBs. I had a similar problem with the same amp and it was the 6l6 sockets. I had to suck the old solder out and resolder.
I'm learning...
