August 29, 2026, 07:22:57 pm
Hoffman Amps Forum image Author Topic: Bias VTL IT-85 doubt - help needed  (Read 6575 times)
Offline Miracle1980
« on: October 16, 2020, 08:35:55 am »
Hello guys,
I bought and installed a matched quartet of 6CA7-Z black Treasure for my integrated amplifier VTL IT-85.
They seem to sound really good but I wait for burn-in before final judgement.
I have a question/doubt about the Bias that I already did:
On the valves box I see there is written "Ia 25mA" (initial current?)
My integrated amplifier (VTL IT-85) has resistance of 10ohm and the bias suggested range is 275mV - 300mV
Can I leave these valves set it up at 275mV safely?
Or should I set it to 250mV (25mA x 10ohm)?
Below the full specs of these valves:
http://shuguangtube.com/Shuguang-Treasure-Vacuum-Tubes-6CA7-Z-new-matched-pair-p30.html
Re: Bias VTL IT-85 doubt - help needed
« Reply #1 on: October 16, 2020, 09:19:05 am »
Ia = ANODE (PLATE) current
how many tubes share the 10ohm, 1 for each tube = 27.5mA
to answer what's acceptable you need plate VDC, then multiply that by .0275A and you have dissipated power for each tube at idle.
Offline Miracle1980
« Reply #2 on: October 16, 2020, 09:39:03 am »
As you can see I don't have much knowledge in electricity... :)
The VDC of the integrated should be around 460 VDC (Push-pull) that multiplied by .0275 is equal to 12.65
Is this a normal/good for these 6CA7-Z? Or do you suggest going lower with mV during Bias?
Offline Latole
« Reply #3 on: October 16, 2020, 10:40:32 am »
Beware, IMO you may do big mistake
275 mv = 0.275 not 0.0275
460 X 0.275 = 126 watts !!!! :help:
Offline Latole
« Reply #4 on: October 16, 2020, 10:43:59 am »
Hello guys,
This is the bias reading on hid matching instrument when dealer matched all four tubes. It is not useful for you.
« Reply #5 on: October 16, 2020, 10:46:04 am »
Not so. His bias sense resistor is 10Ω, not 1Ω. Therefore 275mV represents 27.5mA.
Offline Latole
« Reply #6 on: October 16, 2020, 10:56:13 am »
Right, I did not understand the use of 10 ohms, I am not an English speaker
Offline Miracle1980
« Reply #7 on: October 16, 2020, 11:07:18 am »
Hello guys,
Thank you. So can I stick with 275mv or would you recommend something lower...for example 265mv?
« Reply #8 on: October 16, 2020, 11:59:10 am »
My reading of the OP is that the manufacturer has provided a target range of 275-300mV for the bias check measurement? If so, why query that?
Offline Miracle1980
« Reply #9 on: October 16, 2020, 12:36:54 pm »
Actually you are right. I got confused by the 25mA (matched voltage by dealer) written on the valves box. I think the "non problem" is solved  :)
