September 14, 2026, 03:26:13 pm
Hoffman Amps Forum image Author Topic: Reverb tank replacement for Deluxe Reverb AB763 rebuild  (Read 8673 times)
Offline W1Jrv
« on: October 17, 2020, 05:16:04 pm »
i had my 65' Deluxe Reverb RI rebuilt as AB763 a few years ago. basically completely gutted. replacing a few tubes recently i looked at the reverb pan. it is a Accutronics & Belton Model 64063 year 2011/04/13. it was in the leather bag open side down upon a piece of cardboard about the same dimensions as the pan. only the ends of the bag were screwed down into the cabinet floor. i.e., the pan was a bit loose in the bag.
1. would it be better to use 4 grommets and screw the pan itself to the floor of the cab? Does the cardboard piece stay also or is there better material?  i guess the pan stays in the bag too?
2. it is a 2/4 spring type pan. would a 3/6 spring pan upgrade be better? i'm wanting to try a 3 spring pan and check out the difference.
   my understanding is i need to keep a new pan at the the same "INPUT IMPEDANCE & OUTPUT IMPEDANCE". is this correct?
   anybody know what those values are for this reverb pan/amp? is it like the Fender 4AB3C1B which is 8 ohms, 2250 ohms respectively.
Re: Reverb tank replacement for Deluxe Reverb AB763 rebuild
« Reply #1 on: October 17, 2020, 05:26:19 pm »
The mounting is fine just as it is.
If you want to try a 3 spring unit you will need the 9AB3C1B.
     https://www.tubesandmore.com/products/reverb-tank-accutronics-9ab3c1b-long-decay-3-spring
Offline W1Jrv
« Reply #2 on: October 19, 2020, 02:09:48 am »
OK then. thanks for link!!
