August 29, 2026, 07:22:59 pm
Hoffman Amps Forum image Author Topic: Mounting Tube Sockets  (Read 8146 times)
Offline yorgle
« on: October 21, 2020, 02:59:15 pm »
On all of my builds so far, I've used #4-40 machine screws and nuts to bolt tube sockets to the chassis.  Once I'm satisfied that I don't need to take things apart again, I put a dab of superglue on the exposed threads/nut and that has worked well for my limited, living room use.  But I wonder how that would hold up if the amp were being dragged/banged/kicked/dropped about to and from gigs.  What do the grey-beards here use?
Re: Mounting Tube Sockets
« Reply #1 on: October 21, 2020, 03:18:49 pm »
I use 4-40 but I just tap the chassis. I don't use a nut. And I don't abuse my amps by playing them!   :l2:
But, if the amp were being dragged/banged/kicked/dropped about to and from gigs, I would put a drop of Loctite thread-locker on the screw threads then put a kep nut on the screw. Probably a good idea for every screw in the amp, especially on transformers.
Offline bmccowan
  • Better builder than player
« Reply #2 on: October 21, 2020, 05:29:29 pm »
I have a big grey beard so I guess I have to answer - I use kep nuts throughout the chassis. #4s for 9 pin sockets and 4s or 6s for octals, 8s for trannies. My amps stay home, but if I did tote them around I'd prefer the Loctite. I've used that on bicycles and motorcycles for years with good success. One of my bikes is a vintage Triumph - that thing needs lots of Loctite. :icon_biggrin:
Mac
John Prine
« Reply #3 on: October 21, 2020, 05:40:36 pm »
I thought you used rivets. Maybe my memory is gone.
« Reply #4 on: October 21, 2020, 05:56:29 pm »
Oh no. Never used any rivets.
     http://sluckeyamps.com/supro/supro_02_big.jpg
Offline Latole
« Reply #5 on: October 21, 2020, 06:07:20 pm »
I use bolt, lock washer and nut,
Never rivets.
« Last Edit: October 21, 2020, 06:19:20 pm by Latole »
« Reply #6 on: October 21, 2020, 06:39:44 pm »
I started with nuts n bolts n washers....bought rivets, gives it that '40s feel  :icon_biggrin:
« Reply #7 on: October 21, 2020, 07:41:54 pm »
Offline AmberB
« Reply #8 on: October 21, 2020, 07:58:53 pm »
Kep nuts here also.
Offline Latole
« Reply #9 on: October 22, 2020, 02:50:36 am »
It's include kep nut in my answer 'cause they are nut with lock washer.
In other word, bolt and nut is not enough to stay tight over years
Offline FranciscoPerez
    • 22 nanofarads
« Reply #10 on: October 22, 2020, 05:56:37 am »
I use a lock washer, and locknuts. No loctite, and always worked great.
I started doing this after I read a document from Rod Elliot about earthing:
https://sound-au.com/earthing.htm
Offline Latole
« Reply #11 on: October 22, 2020, 06:02:42 am »
For tube socket, wich is the subject ;
It's like using a belt and suspenders to hold your pants no ?
If you want to use locknut, regular flat washer is enough to hold any mechanical stuff.
Teeth or lock washer is a must for electrical connection to "bite" into the metal and ensure a good contact and to hold nut always tight.
« Last Edit: October 22, 2020, 06:15:52 am by Latole »
    • 22 nanofarads
« Reply #12 on: October 22, 2020, 06:12:42 am »
Regular flat washer is enough.
hehe Yes, I guess you are probably right. I connect my mains safety earths like this, see attachment, so I guess I got used to use both locknuts and lock washers.
« Reply #13 on: October 22, 2020, 06:16:13 am »
Your pic looks like a locknut and flat washer?
Offline Latole
« Reply #14 on: October 22, 2020, 06:17:29 am »
Too much hardware for small job,
If you built a bridge this way it would cost so much that no country could afford it and it would be so heavy it would collapse.... :l2:
« Last Edit: October 22, 2020, 06:20:16 am by Latole »
    • 22 nanofarads
« Reply #15 on: October 22, 2020, 06:24:33 am »
Yes, it looks like flat but it's a lock washer. See how it's not flat touching the chassis, but stays somewhat above while the teeth are biting it
    • 22 nanofarads
« Reply #16 on: October 22, 2020, 06:30:55 am »
Hahaha, yeah too much hardware for a tube socket I suppose.
Safety earth connection is another story, though, and regulations vary from country to country.
« Reply #17 on: October 22, 2020, 06:56:41 am »
for the 7 & 9 pin miniature sockets, i use 4-40 hardware with keps (k-lock) nuts and an internal tooth washer on the bolt head end.
for octal i use 6-32 with the same washer/keps nut/ compliment.
« Reply #18 on: October 23, 2020, 12:40:50 pm »
Yes, Elliot recommends just that while acknowledging this earth ground setup as overkill.  But FranciscoPerez is off topic:  Elliot says this ONLY for the ground connection and not to be used for components such as a a tube socket, the topic under discussion:  "Do not use the earth connection as mounting for any other panel or component - it must be dedicated to the task of providing a safety earth point.  If a component mounting bolt is used, at some stage it may be disconnected by a service (or other) person, which means that the apparatus is unsafe until everything is (hopefully) put back where it belongs - this does not always happen."
Offline Soulfetish
« Reply #19 on: October 23, 2020, 05:39:20 pm »
I use M3 fasteners for most all my 9-pin sockets, and standoffs.
It may seem a bit pedantic, but I think its far superior to 4-40. Im an American, and I think all metric threads are for the most part.
For small insulated turrets and terminals, they often have 2-56 threads, so I’ll usually tap the chassis to mount them directly using thread locker.
Offline glass54
« Reply #20 on: October 23, 2020, 08:59:46 pm »
+1 with Sluckey
When I have had to repair/replace sockets, and they have been riveted, can be a pain to drill out the rivet neatly. It was a common practice in Australia for a couple of manufacturers in the 60's and 70's to use rivets.
We're Metric in Aussie so I use an M3x6 with Locknut but it's fiddly. Don't mind the screws in Noval Skts as long as the chassis thickness is sensible.
Soulfetish "Pedantic" is good  :laugh: :l2:
Regards
Mirek
« Last Edit: October 23, 2020, 09:06:11 pm by glass54 »
"To measure is to know"
