August 29, 2026, 07:29:03 pm
Hoffman Amps Forum image Author Topic: Ampeg B-15NF  (Read 4728 times)
Offline Big chief
Ampeg B-15NF
« on: October 25, 2020, 04:45:41 pm »
Have no sound to speaker all tubes light up used Ext speaker jack and used normal speaker jack.  Problem v5 flickers when touch tip of guitar cable
V1 volts pin 1-0.2 pin 2-194.1 pin 3- 1.9 pin 4-0 pin 5- 163.0 pin 6-2.3 pin7 0.6 pin 8 5.9
V2 volts pin 1-0 pin2 193.3 pin 3-1.9 pin 4-0 pin5-161.8 pin6- 2.2 pin7-0.6 pin8 5.9
V3 volts pin 1 0 pin2 237.0 pin3- 2.4 pin4 0 pin5-246.7 pin6-2.2 pin7- 0.6 pin8 5.9
V4 volts pin 2-0.6 pin3-481.3 pin4-476.4 pin5-40.0 pin7-5.9 pin8-0
V5 volts pin 2-0.6 pin3-479.4 pin4-475.1 pin5-36.5 pin7-5.9 pin8-0
V6 volts pin2-0.6 pin4-402.2 pin6-408.4 pin8-491.2
V1-3 6SL7. V4-5 6L6 v6 5AR4
Any help would be great as I’m trying to help a friend
Re: Ampeg B-15NF
« Reply #1 on: October 25, 2020, 05:08:02 pm »
schematic
https://el34world.com/charts/Schematics/files/Ampeg/Ampeg_b15n.pdf
looks to be an AMP out jack, tried that?
Offline Big chief
Re: Ampeg B-15NF
« Reply #2 on: October 25, 2020, 06:53:24 pm »
This may sound dumb I have never hooked up one amp to the other
Do You have second amp power on or off
Please tell me how to perform this task
Offline AmberB
Re: Ampeg B-15NF
« Reply #3 on: October 25, 2020, 08:13:46 pm »
Is the speaker good?
Offline Big chief
Re: Ampeg B-15NF
« Reply #4 on: October 26, 2020, 06:58:28 am »
Speaker appears to be ok also have used ext 8 ohm jack with known good speaker.
Possible short some where at V 5
Re: Ampeg B-15NF
« Reply #5 on: October 26, 2020, 08:20:56 am »
make it easy, got a  junk set of "powered" desktop speakers.  come up with a 1/4(preampout) to 1/8"(? speaker in), turn your amp to 1 or 2, turn powered speakers to 5, strum n listen.
or you could rebuild v5 if you think it's a problem n see
Offline Latole
Re: Ampeg B-15NF
« Reply #6 on: October 26, 2020, 10:26:36 am »
Do you hear hum at speaker with full volume if need ?
 You must be sure all tubes are good. Are you ?
Do you have a 'scope to follow guitar sound trough the amp circuit ? Use of signal generator is easier
No  !
 Use a voltmeter on AC scale plug at each tube input ( grid) and output ( anode )
You must read some millivolts when playing guitar.
Follow the circuit , you will see where there are no reading ; issue is there
« Last Edit: October 26, 2020, 10:33:58 am by Latole »
Offline 2deaf
  • Now too deaf for 100 watts
Re: Ampeg B-15NF
« Reply #7 on: October 26, 2020, 01:09:50 pm »
You know, if you take that literally, it sounds like you are hooking the output of one amp to the output of another amp.
Offline Big chief
Re: Ampeg B-15NF
« Reply #8 on: October 26, 2020, 10:31:31 pm »
Had loose joint on v5 also had wire loose on speaker
Thanks for all your help
Sounds good now
