September 08, 2026, 12:19:52 pm
Hoffman Amps Forum image Author Topic: Built my own DIY pickup winder, looking for starting point on a humbucker  (Read 6938 times)
Offline paintballnsk
Hey guys,
Anyone have any experience winding pickups with a CNC winder (or by hand)?
I am just looking for a good starting point to try my first humbucker. I assume this will take quite a bit of trial and error. My favorite pickup tends to be the Duncan JB, goes in most of my guitars. I'd like something in that ball park, with just a little less "quack" in the mids.
The pickup is going in the bridge of a PRS 20th anniversary single cut, which currently has Tremonti pickups in it.
I'm using 44g wire. Alnico 5 magnet.
Any suggestions on how many windings I should do on each bobbin and how fast I should oscillate the "hand"? I have a motor hooked up to the "hand" which can oscillate up to 11 RPM (from left of bobbin, to right, and back again). The bobbin spinner can rotate up to 1000RPM.
« Last Edit: October 28, 2020, 01:47:43 pm by paintballnsk »
Offline shortfuse
Stew Mac has good pdf instruction sheets and spec’s for general assembly and number of winds.  They are listed with their pick up kits.
There are also a ton of vid’s on YouTube on this as well.  Replicating a JB is gonna be a lot of winds.
Just built my pick up winder last week but I am starting with single coils for a strat I built a while back looking to replicate a 50’s early 60’s wind.
Offline Toxophilite
Re: Built my own DIY pickup winder, looking for starting point on a humbucker
« Reply #2 on: November 18, 2020, 12:59:16 am »
All the winds and rewinds I've done have been with dewalt battery powered drill and hand feeding the wire. I did at one point use a wind counter made from 2 contacts wired to the left click of a mouse and used my computers calculator but now I kind of guess and aim for too high. I can always unwind if needed.
The most difficult one I did was an air coil for an old schaller pickup. It took me 3 tries. %&*^%& PITA!!
