August 29, 2026, 07:30:09 pm
Hoffman Amps Forum image Author Topic: Need advice: Help with tube preamp output (pedal)  (Read 3504 times)
Offline vratocaster
« on: October 29, 2020, 09:43:47 pm »
Hi guys... I'm starting with a tube preamp pedal based in sluckey marshall  schematic. The output signal will be ok to work with a power amp/power amp in.
My question is: How I can get properly line signal to go from the preamp output to feed pedals? Do I need some pad attenuation? The 1 meg master volume pot will be enough to drive the properly signal level?
Re: Need advice: Help with tube preamp output (pedal)
« Reply #1 on: October 29, 2020, 09:53:06 pm »
Probably gonna need a cathode follower after the master volume pot.
Offline vratocaster
« Reply #2 on: October 29, 2020, 10:19:26 pm »
Thanks @sluckey! Please give some advice, Wich is better in this case ?  Triode CF or  Mosfet CF?
« Last Edit: October 29, 2020, 10:23:19 pm by vratocaster »
