August 29, 2026, 07:28:54 pm
Hoffman Amps Forum image Author Topic: Vox ac15 sanecore output transformer wiring?  (Read 4093 times)
Offline jammied
« on: November 06, 2020, 09:24:40 pm »
Ok I dug through my parts bin from years ago and found a sanecore output transformer. I believe it was from a ac15 maybe ac10?
But cant seem to find a wiring diagram for it? Thought about using it in a 5e3 type of build.
So years ago I taped the red, white and yellow wires together so I'm assuming these were the primaries and center tap?
And the left over wires are black, orange and blue. Now I'm assuming black is speaker ground, orange is 16ohm and blue is 8ohm?
I did some internet searches but couldn't find any color coded hookup diagrams or info.
Re: Vox ac15 sanecore output transformer wiring?
« Reply #1 on: November 07, 2020, 05:01:52 am »
so I'm assuming
try ohming the wires, that eliminates some assuming  Note: the secondary's will be few ohms
Offline jammied
« Reply #2 on: November 07, 2020, 07:29:14 am »
Yeppers done it
Red to yellow= 135ohms
Red to white = 133ohms
Yellow to white = 267ohms
Black to blue= .7ohms
Black to orange =.6ohms
Orange to blue=.2ohms
Primary looks correct
But still not sure of what tap would be 16ohm on the secondary. I really thought the orange wire is 16ohm and blue is 8ohm.
Guess I can get a known transformer and compare
« Reply #3 on: November 07, 2020, 07:49:59 am »
Put a voltage into the primary. Measure the voltages on the secondaries. The larger voltage will also be the larger impedance.
