September 15, 2026, 12:10:28 am
Hoffman Amps Forum image Author Topic: Layout for small DR single channel  (Read 5158 times)
Offline acheld
« on: November 18, 2020, 03:51:34 pm »
I'm laying out a build for single channel Deluxe Reverb, using Doug's board.  The goal is to reduce the size of the chassis as much as possible -- yet maintain low noise and no hum.   Previous DR builds for me have been very quiet.   I'm not trying to build a "mini" or "micro" version, just keep the physical size down.
My question is:  How closely spaced can a PT, choke, and OT be and remain quiet, assuming one orients each of the transformers correctly?
Related question:  What is the optimum position for a reverb transformer?  I have had problems with reverb hum in the past, and have wondered about this as a cause.
Offline acheld
Re: Layout for small DR single channel
« Reply #1 on: November 18, 2020, 09:25:55 pm »
Photo of rough layout is shown.   Chassis is about 20 inches in overall length.
I'd like to keep all of the transformers as far away from the input as possible.
And try to keep the hummm out of the reverb.
Offline AmberB
« Reply #2 on: November 18, 2020, 09:32:04 pm »
Well, considering that I've seen some amps with the transformers placed right next to each other, I'd think your layout should work pretty well.
Offline drew
« Reply #3 on: November 18, 2020, 10:32:13 pm »
If only Fender made a smaller than a DR, single channel, 2 power tube amp with trem and reverb whose physical layout you could just copy . . .  :think1:
Offline dwinstonwood
« Reply #4 on: November 18, 2020, 10:33:10 pm »
I recently finished this amp in a compact chassis - Hoffman Stout. Here's how I configured the TX's. It's a very quiet amp (I got a lot of help from sluckey). But, I don't have a reverb TX.
« Reply #5 on: November 19, 2020, 05:12:06 am »
the only place i'd locate a reverb transformer in that chassis is internally, away from the power section, or on the back, again, away from the power switch and high current PS circuit elements.
IME, a modified plexi chassis (use 2 inputs) is good fit. also, have a look at the 17"x 6" chassis that doug sells as an option.
Offline acheld
« Reply #6 on: November 19, 2020, 08:37:00 am »
Thanks very much.  The advice is appreciated!
Interested in your comment about the reverb transformer -- is there a disadvantage to the usual Fender layout with the transformer outside the chassis and near the transformer recovery tube?     Would inside the chassis really be helpful?  (I won't have room for that, but am curious).
« Reply #7 on: November 19, 2020, 09:27:07 am »
I think he's talking about that tiny 12" chassis in post #4. There's plenty of room on your 20" chassis.
Offline Bieworm
  • I like it loud!
« Reply #8 on: November 19, 2020, 11:14:14 am »
A princeton reverb chassis? That's single channel. Should be easy to adapt...
