September 18, 2026, 12:53:14 pm
Hoffman Amps Forum image Author Topic: Isolation transformer question  (Read 4423 times)
Offline yorgle
« on: November 24, 2020, 09:53:45 am »
I recently acquired a Tektronix 2225 scope and before I start learning how to measure with it, I figured I should first make sure I know how not to fry it (or myself).  I'm faced with the seemingly perennial question of do I need  an isolation transformer?  I've watched some Uncle Doug's excellent videos and wasted many hours reading online arguments, so I do understand that because the ground clip on the scope probe ultimately connects through the scope to ground, it can make big ZAP if it gets clipped to a hot or neutral point.  Therefore, the unit being tested must be isolated from the mains.  That makes sense to me if I were to go poking about about inside an old "hot chassis" amp.  But if the unit being tested is an amp with a power transformer, won't it already be sufficiently isolated (except for the primary side) as long as I use a 3-2 prong "cheater" plug on the power cord?
Re: Isolation transformer question
« Reply #1 on: November 24, 2020, 10:10:52 am »
There is no danger when testing that has it's chassis bonded to earth with a green wire in a 3 prong power cord. Don't use a 3-2 prong cheater.
