September 16, 2026, 05:22:23 am
Hoffman Amps Forum image Author Topic: Marshall jvm410 Rustleing paper sound until warmed up.  (Read 5315 times)
Offline Captain chunkulus
« on: November 26, 2020, 10:03:26 am »
Okay so I have this Marshall jvm410 head. As the title reads, has rustling paper like sound upon startup. Power It Up and let it sit for a little while and no matter how long I let it sit before I take it off standby it does the same thing. the wrestling paper sound for a little while. Seems to go with the bias. As the bias increases as the amp is warming up, the rustling paper sound is in effect so to speak. I bought this amp second-hand and it appears that someone modded the bias circuit. The values are the same in regards to the resisters. They changed out the pots for the bias circuit. I'm guessing so they coud bias the amp for something other than el34s. I'm not really sure. Any ideas on what might be causing the rustling paper sound. I goes away after a while. I've changed out all the power tubes and all the preamp tubes with brand new tubes does exactly the same thing regardless of what tubes are in it. Thanks guys.
Offline Latole
Re: Marshall jvm410 Rustleing paper sound until warmed up.
« Reply #1 on: November 26, 2020, 12:40:13 pm »
".. the wrestling paper sound for a little while. Seems to go with the bias."
-Captain chunkulus,
Like a SHRHRHRHH ?
Is the bias is the good one ?
Or it is a bad solder in power supply ?
« Last Edit: November 26, 2020, 02:59:06 pm by Latole »
Offline Latole
« Reply #2 on: November 26, 2020, 02:58:39 pm »
Or stanby switch arcing ?
« Reply #3 on: November 27, 2020, 09:35:02 am »
How would I determine standby switch arching?
Offline Latole
« Reply #4 on: November 27, 2020, 09:48:19 am »
IMO reading ohms with a meeter may show some resistor at stanby switch contacts.
You should disconnect all wire from the switch.
Discharge filter caps before, lethal voltage ; amp disconnected from the wall outlet, power ON and stanby switch to Play, wait half hour or less if you can read voltage at filter caps to see voltage drop close to few volts or 0
« Last Edit: November 27, 2020, 09:55:02 am by Latole »
« Reply #5 on: November 27, 2020, 11:47:42 am »
How about if you power up without a tube in the V5 phase splitter socket?
« Reply #6 on: November 27, 2020, 11:57:07 am »
No sound at all with the phase splitter pulled.
Offline Latole
« Reply #7 on: November 27, 2020, 12:14:49 pm »
"Any ideas on what might be causing the rustling paper sound. I goes away after a while."
- Captain Chunkulus
I wonder if it wouldn't be a signal cap that would have a momentary DC leak ?
« Reply #8 on: November 27, 2020, 12:29:25 pm »
How about if a shorted jack plug is plugged into the PA in return jack? Could use a lead with a guitar whose vol controls were turned to minimum.
If no noise, how about the same with the fx loop return jack?
