September 15, 2026, 11:06:39 pm
Hoffman Amps Forum image Author Topic: Hammond OT for Plexi 6v6 build?  (Read 5565 times)
Offline mcamelo
  • Tube noob
« on: November 28, 2020, 04:47:45 pm »
Hi, all.
I'm starting a Plexi 6v6 build and trying to find a suitable OT. Preferrably a Hammond since I can usually get them from Digikey delivered to Australia with free shipping (but open to alternatives).
I've found this one listed as suitable for 18W marshalls: https://au.mouser.com/ProductDetail/Hammond-Manufacturing/1750PA?qs=lrqjml%252Bjt8cxDhP5xJ0Rrw%3D%3D  but I'm not sure how well it suits the Plexi 6v6.
I can't yet on my own calculate the tubes power output or OT primary impedance from the schematics. If anyone can tell me what they are, I could use that to go shopping for a suitable OT.
:help:
Any pointers will be greatly appreciated.
Re: Hammond OT for Plexi 6v6 build?
« Reply #1 on: November 28, 2020, 05:07:54 pm »
you calculate based on operating conditions, not schematic, or look at a tube datasheet and aim for a specific set of spec's.
that said the one you referenced appears fine
Offline vampwizzard
    • Walbertedwards.com
« Reply #2 on: November 28, 2020, 08:32:59 pm »
Should be good. MHuss used an 18 watt spec'ed for his build.
Offline AmberB
« Reply #3 on: November 28, 2020, 11:23:51 pm »
It looks like that OT is rated at 8.4k secondary and 18 watts output, so it should work well for a pair of 6V6s...
Offline Latole
« Reply #4 on: November 29, 2020, 03:39:15 am »
Primary not secondary  :laugh:
mcamelo, OT will work
« Last Edit: November 29, 2020, 03:43:09 am by Latole »
« Reply #5 on: November 29, 2020, 03:45:48 am »
It seems a quirk of guitar amp evolution that only the high power models were deemed worthy of OTs with a decent spec. I suggest to consider something beefier, interleaved for better performance, more akin to a 784-139.
Unfortunately I’m not aware of anything with an 8k primary that meets that criteria other than OT intended for JTM45, eg 1750Q, which is way more expensive.
EDIT Another option would be the hifi 25W 1650FA but that’s even more pricey.
« Last Edit: November 29, 2020, 03:56:50 am by pdf64 »
« Reply #6 on: November 29, 2020, 04:50:14 am »
1750E
1760E
1750F
1760F
1750FA
1750PA
are all suitable parts in the hammond line.
Offline mcamelo
  • Tube noob
« Reply #7 on: November 29, 2020, 02:55:05 pm »
you calculate based on operating conditions, not schematic. look at a tube datasheet and aim for a specific set of spec's.
I was thinking it was the circuit design that determined the operating conditions by setting the plate, cathode and grid's idle currents but, looking at the Tung-Sol 6v6 datasheet, I now see that it lists typical operating conditions. Makes sense.
Quote from: shooter
Thank you and everyone else that chimed in with guidance.
I will look at all the options and comeback with more questions if I have any.
