September 18, 2026, 10:51:57 am
Hoffman Amps Forum image Author Topic: "Correct" fuse and switch wiring for 3 prong  (Read 9720 times)
Offline jordan86
« on: December 01, 2020, 04:54:35 pm »
I replaced the 2 prong AC cord in my 65 Showman recently with a grounded 3 prong, bypassing the ground switch and death cap. I took the "simplest" path based on the stock wiring.  Example A below. It allowed to not remove any more wiring than necessary based on the way the PT was originally wired. Wondering if Example B would be better, safer, more up to modern "standards". I'm no electrician :)
Ex. A is actually how I wired my first amp build (AA1164) based on the Mojotone Kit instructions, so I presume it's not too unsafe.
Re: "Correct" fuse and switch wiring for 3 prong
« Reply #1 on: December 01, 2020, 05:13:11 pm »
"B" is preferred. The important thing is that you have the green wire from your power cord securely connected to chassis.
I would replace that two prong convenience outlet with a "proper" three prong outlet or just disconnect it. I think user "p2pAmps" has found a source for a 3-prong outlet that fits.
Offline jordan86
« Reply #2 on: December 01, 2020, 05:57:50 pm »
Thanks, Sluckey. Yes, ground wire is definitely secured on chassis. Again, left the hot/neutral in the "sort of stock" scenario to minimize changing too much on the old amp. I have no intention of actually using the convenience outlet. It was more so about not moving the primarily side leads on the transformer.
I take "preferred" to mean it works fine as is? No major red flags?
« Reply #3 on: December 01, 2020, 09:27:20 pm »
Inside the appliance chassis, it does not matter.
You NEVER know which prong is "live". (There is a right way to wire a wall outlet, but 6 out of 10 outlets in my kitchen were wrong, and the US average is not a lot better.)
You can always get shocked changing the fuse (a popular objection), unless you go to a DP switch (almost unknown in America). UNPLUG before changing fuse--- most appliance safety rules are based on PLUG CONNECTION and total isolation after a 2-second disconnect.
Offline Latole
« Reply #4 on: December 02, 2020, 03:30:58 am »
Answer ; B
Always fuse and switch the hot side
Il put fuse before the switch.
I'll remove death cap
Offline jordan86
« Reply #5 on: December 02, 2020, 10:34:38 am »
Yes, this was the one concern on my mind. Changing the fuse while plugged into the wall. Just didn't know if there were others. I think I am content to run that risk myself for the time being, but I definitely want to revisit it. Especially if I ever sell.
Thanks guys!
« Reply #6 on: December 02, 2020, 11:13:53 am »
You can reduce the risk of shock by connecting the hot line wire to the end lug of the fuse holder, never to the side lug. Like this...
     http://sluckeyamps.com/misc/AA864_Musings.pdf
