September 16, 2026, 07:44:56 pm
Hoffman Amps Forum image Author Topic: Transformers for 4x6v6 and 4xel84 builds  (Read 6811 times)
Offline steveo7868
« on: December 01, 2020, 07:11:07 pm »
I have always wanted to try a 4x6v6 build I was going to try this Edcor power
XPWR007
Power transformer for a 120V, 60Hz. or 240V, 50/60Hz. line to 550V (275-0-275) at 200mA center tapped, 6.3V at 6A and 5V at 3A.
I think a 50W marshall transformer should work or even a 4k bandmaster type rated at 40W should work
I really think the Iron for  a Vox AC30 is overkill, I have built a 4xel84 amp with a hammomd 270-FX
and a 4k bandmaster type with decent results
but I  thought this edcor was cool with the extra current
I plan to use cathode bias
Is there a good value for the 4x6v6 amps? like pair of 250 5W or ?
or is it better to go fixed bias?
thanks
Offline vampwizzard
    • Walbertedwards.com
Re: Transformers for 4x6v6 and 4xel84 builds
« Reply #1 on: December 01, 2020, 07:38:02 pm »
this is a good tool for planning your current needs: https://thesubjectmatter.com/calcptcurrent.html
Offline AmberB
« Reply #2 on: December 01, 2020, 08:16:14 pm »
As for the output transformer, you can use the same push-pull OT for 2 6L6s on 4 6V6s.  The impedance works out about the same, and the transformer will definitely handle the power of  4 6V6s if it will handle a pair of 6L6s.
Offline bmccowan
  • Better builder than player
« Reply #3 on: December 02, 2020, 10:30:54 am »
Interestingly enough I have transformers from both Baldwin 4xEL84 amp; and Hammond 4x6V6 amps. My plan is to use that iron in 2x6L6 amps. I'm not foreseeing a problem with that. Close enough for rock & roll!
Mac
John Prine
Offline steveo7868
« Reply #4 on: December 02, 2020, 12:28:49 pm »
I guess I just wonder why a Vox Ac30 replacement  transformer has 270MA of current and a 100W Marshall has about 290ma am I missing something?
« Reply #5 on: December 02, 2020, 02:32:46 pm »
Different voltages? (P=V*I)
« Reply #6 on: December 02, 2020, 03:04:41 pm »
Which 100W Marshall PT has 290mA?
Offline steveo7868
« Reply #7 on: December 02, 2020, 06:38:33 pm »
classictone 40-18024 has the 290 ma
Sorry guys I am going to chill out I should not post
I get these ideas half baked and think I need to post
I am going to build my amp eventually  and see how it goes
