September 16, 2026, 02:57:41 pm
Hoffman Amps Forum image Author Topic: Better bass response  (Read 4877 times)
Offline newguitarsmell
« on: December 01, 2020, 08:43:38 pm »
Hey all
I modified a 5f2a to use with keys - put in a huge OT - - a nice big speaker but the bass response is a bit flat. Maybe I'm asking too much of a single ended 5Watter?
The tone control helps kick out the top end but it needs more.
https://el34world.com/Hoffman/files/Hoffman_5F2A.pdf
Nice and quiet though - sounds great overall I am happy with it. Just wondering. Haven't checked in for awhile.
Re: Better bass response
« Reply #1 on: December 01, 2020, 10:07:45 pm »
Most likely.
« Reply #2 on: December 01, 2020, 11:18:07 pm »
Sluckey - you would know!
Offline Leevi
    • Rikstone
« Reply #3 on: December 02, 2020, 03:38:13 am »
Add a cathode bypass cap to the second stage.
Cut the NFB.
/Leevi
« Reply #4 on: December 02, 2020, 06:39:08 am »
Cut the NFB.
A fully bypassed 2nd stage cathode would disable the NFB loop (which would tend to result in a brighter sound due to the amp’s output then tracking the load impedance).
Whereas a partial bypass would actively boost higher frequencies (eg same as a presence control on max) :w2:
Offline Leevi
    • Rikstone
« Reply #5 on: December 02, 2020, 07:48:05 am »
A fully bypassed 2nd stage cathode would disable the NFB loop (which would tend to result in a brighter sound due to the amp’s output then tracking the load impedance).Whereas a partial bypass would actively boost higher frequencies (eg same as a presence control on max)
This is true but I think the cap value affects the frequency? A small cap gains high frequencies and a big cap low frequencies?
Furthermore the overall loudness will increase which highlights the bass as well.
/Leevi
« Last Edit: December 02, 2020, 12:01:10 pm by Leevi »
