September 16, 2026, 06:18:19 pm
Hoffman Amps Forum image Author Topic: Artificial Center Tap Resistor Question  (Read 5888 times)
Offline imgumby001
« on: December 02, 2020, 12:22:49 pm »
I need to create an artificial 6.3 center tap on my current build and I don’t have any 1/2w 100ohm resistors, I’ve got a bunch of 1/4w. Is it dangerous to go that low? Will they just blow out?
Thx
Re: Artificial Center Tap Resistor Question
« Reply #1 on: December 02, 2020, 01:14:38 pm »
The arithmetic is simple,
Power = voltage squared / resistance
So 6.3 x 6.3 =40
40 / 200 = 0.2W
That’s 0.1W per 100 ohm resistor.
Personally I used 5W, as in the case of s power tube fault shorting HT current to the heater circuit, I prefer them to hold and blow a fuse.
Offline imgumby001
« Reply #2 on: December 02, 2020, 01:18:49 pm »
So 6.3 x 6.3 =40
40 / 200 = 0.2W
Thanks pdf. The math is what I need more than anything. Knowing where to apply it always alludes me. Looks like I’m taking a trip to radio shack!! Good thing we STILL have one out here in B.F.E.
Offline Latole
« Reply #3 on: December 02, 2020, 01:23:21 pm »
Some amp use 47 ohms 1/2 watts , other use 200 ohms 1/2 watts.  You many choice.
http://www.valvewizard.co.uk/heater.html
« Last Edit: December 02, 2020, 01:27:02 pm by Latole »
Offline imgumby001
« Reply #4 on: December 02, 2020, 02:38:51 pm »
Thanks latole. I just went out and picked up some 100ohm 1/2 watters. It’s about 30min away, but it gave me the opportunity to upgrade my channel switch. I’m hemorrhaging money on this deal. Gotta love it!!
