September 16, 2026, 10:23:06 pm
Hoffman Amps Forum image Author Topic: using a fet follower for a little clean boost  (Read 4609 times)
Offline swingarm
« on: December 02, 2020, 10:06:40 pm »
Hi there guys. I was wondering if this is possible or would it just end up driving the power amp into distortion?
I built a supro clone and decided i did'nt want tremolo. I inserted those two gain stages into the normal channel and made it switchable with the clean channel on a dpdt switch. The distortion channel is very loud and the clean channel is moderate. I know the limitations in the circuit but was wondering if i could use the fet follower to increase the clean signal some. Any thoughts?
« Last Edit: December 02, 2020, 11:05:46 pm by swingarm »
Re: using a fet follower for a little clean boost
« Reply #1 on: December 02, 2020, 10:18:59 pm »
A follower, whether cathode, emitter, or source, always has slightly less output than input. Gain is typically 0.9.  Nothing to be gained here.
Offline swingarm
« Reply #2 on: December 02, 2020, 11:06:54 pm »
Thank you sluckey. It is what it is then :)
« Reply #3 on: December 02, 2020, 11:20:02 pm »
There may be other options. Can you post a schematic that shows what you have now?
Offline swingarm
« Reply #4 on: December 03, 2020, 12:13:33 am »
I tried to post a schematic but it must not like my browser. I tried 3 time
Offline swingarm
« Reply #5 on: December 03, 2020, 12:34:49 am »
ok im going to try again
Offline swingarm
« Reply #6 on: December 03, 2020, 12:39:40 am »
There should be another coupling cap before the switch . The amp is working presently. Thanks for any ideas you might add.
Offline d95err
« Reply #7 on: December 03, 2020, 12:50:18 am »
I would add a voltage divider to the output of the additional gain stages (before the second half of the switch), to make the level more balanced.
Offline swingarm
« Reply #8 on: December 03, 2020, 01:03:10 am »
Oh okay, yeah that makes sense. Thank you!
