September 18, 2026, 05:41:19 am
Hoffman Amps Forum image Author Topic: 5e3 build voltages  (Read 5874 times)
Offline GreaseBall
5e3 build voltages
« on: December 14, 2020, 05:45:24 pm »
I've just finished building my first ever tube amp. I'm nothing of an electrician but I know a little about soldering  :smiley:. It works, clean tones are really nice but the overdriven sound is quite harsh and trebley sounding. I just thought that maybe someone more experienced than me could throw an eye on this build. I used the Hammond 291BEX power transformer.
I'd appreciate any feedback, thank in you in advance guys
Re: 5e3 build voltages
« Reply #1 on: December 14, 2020, 06:05:50 pm »
Your voltages are way high for a 5E3. The output tubes are idling over 34 watts! Could be part of your issue. You can drop the voltages by using a real NOS 5Y3, unless this is already the case.
Are you using a 12AY7 for V1?
Offline GreaseBall
« Reply #2 on: December 14, 2020, 06:39:12 pm »
Yes, I'm using 12AY7 for v1. So the rectifier could be the problem? It's a TAD 5Y3GT
« Reply #3 on: December 14, 2020, 07:01:07 pm »
How much AC voltage do you measure on pins 4 and 6 of the rectifier tube?
Offline GreaseBall
« Reply #4 on: December 15, 2020, 08:06:51 am »
It's 335V AC between ground and pins 4 and 6. My wall voltage is 230V if it makes any difference.
Offline GreaseBall
« Reply #5 on: December 17, 2020, 08:53:19 am »
Ok, I've changed the rectifier to JJ 5Y3S and now it seems to be fine.
B+1: 360 vdc
B+2: 320 vdc
B+3: 237 vdc
My amp sounds significantly smoother now, much more like I would want it to sound.
I think there was something wrong with the rectifier I've had before, there's 5U4M written on it, so I don't know if it was the right tube.
Offline Latole
« Reply #6 on: December 17, 2020, 09:58:58 am »
How about a bigger value for 6V6's bias resistor ?
I often use Zeners diode stack to have a lower B+ voltage.
https://robrobinette.com/Generic_Tube_Amp_Mods.htm#B+1_Voltage
« Last Edit: December 17, 2020, 10:05:45 am by Latole »
Offline JB
« Reply #7 on: December 17, 2020, 10:13:56 am »
B+1: 360 vdc
B+2: 320 vdc
B+3: 237 vdc
That's almost exactly what I measure in my 5E3.  Enjoy it!
